Hi JB, as you obviously know the racing rules. A plywood racing dinghy, a Snipe if I remember correctly, at the entrance to the dinghy park. A large hole in the side and the written caption, 'I was on Starboard.'
Cheers, Nerys
Cheers, Nerys
Hi Jim,
Thank you for your offer for the Wave Princess plans and build instructions.
I would like to take you up on your offer and maybe do a build of it (from your plans) on here?
I have sent you a PM.
Many thanks,
Hi Jim,
Many thanks,
Hi Jim
How terrible, and what kind of modeller damages another's model and shows no remorse or offers compensation.
We have rules in my club that require the offender to apologise and make good or be subject to a meeting with the committee which could result in expulsion. We all make mistakes but this is our hobby for enjoyment without causing damage.
As Colin says the offenders third party insurance may pay, that's assuming he had any.
Looking at the damage I would carefully check for any splits running beneath the paint from the damage area requiring a possibly bigger hole than the damaged area. Colin's method will work if you use thin ply strips cut to fit and glue inside the hull and to the former. The former should help with getting the correct shape. You could use several layers of thin glued ply to build up to the hull profile making a very strong repair that should sand to be almost invisible.
I hope the repair goes well and that you share the method used for the benefit of our members.
Hi Jim
Hi Jim, bit of a shame, but at least it's fixable, just a bloody nuisance. I had a similar thing happen to my 18ft 'A' Class Cat, while sailing in a big cat marathon on Auckland harbour, when some shirt lifter on a windsurfer jumped off in front of me, and kicked his board out as he did,- straight into my port hull, putting a huge horizontal split in it under the center cross beam (cold moulded ply hull) about 6"above the waterline. He was going to try and escape, but I forced him to shore, and threatened him or his board with bodily harm if he didn't do something.
He went off in his car, and came back with loads of masking tape and blue tack which I lathered onto the hull, as I had about 10 miles to sail back to the start where my car was. By the time I got back, all the tape had fallen off, but luckily no water got in. Had to withdraw from the race (was catching up with the leaders at that stage), but had a nice surprise about 2 months later, when I had a letter from the organisers telling me I had won the draw for a 6 day trip to Fiji, staying at the Sheraton Resort in Nadi, - sort of made up for it !
Repaired the hull by cutting a layer of lamination all round about 2"back from the crack and laying layers of f/glass cloth in the recess. Worked out well, and you couldn't tell it was there afterwards. Luckily the hull was Dynel covered which took a lot of the impact.
[{"id":"163668665935","name":"163668665935.jpg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/163668665935\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/163668665935\/s","isImage":true,"ext":"jpg"}]
Jim, I'm happy you found my suggestion useful.
If there is much curve in the area it may be beneficial to pre curve the ribs, also not having the actual size of the damaged area, it may also need the new skin panel pre-bending.
Give me a shout if you need any more information.
Hi guys thanks for the commiserations. It looks worse than it is l will have to complete the repair the way Colin H ( cheers Colin) described as there is a full bulkhead just behind the break, cant access it from the inside.
Regards Jim.
Regards Jim.
Hi Jim, have had similar damage to a couple of boats, that only had access via the hole made by the damage.
In both cases I repaired without further damage to the hull, by carefully cutting away the splintered surrounding edge, then cutting a new piece to fit exactly in the hole.
Before fitting the new piece I cut braces out of 4x4 timber longer than the hole and glued in place inside to act as ribs to stick the new piece to.
I would cut at the blue line and fit ribs at yellow lines.
Once all set I then sand and fill Before coating with ezekote and glass cloth.
After which you can sand and finish in your chosen method.
I hope this helps with your problem.
[{"id":"163665279792","name":"163665279792.jpg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/163665279792\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/163665279792\/s","isImage":true,"ext":"jpg"}]
Sorry to here and see the damage done to your boat. If the SOB cared about others he would have been beside himself saying sorry. I do hope you find a repair for the boat damage looks extensive.
Rick
Rick
Great Idea, having a burlary in which the Basxxxx took my wood chisels and punched 5 holes in the deck of my A class.
Hi Jim,
As a fast boat user myself I am aware of just how quickly things can go wrong and so I take care to be "extra polite" and only run my boats at low speed unit I have cleared the area where others may be operating and then I make some "white water" when it is safe to do so!
I like "classic model power boats" from the 1960's sort of time period (some earlier some later) and so I restore quite a few - and some have had damage like yours now displays ( tragic!).
Sadly, I don't yet have a Wave Princess in my fleet, so I am not sure what access you have from the inside to make a repair in that position.
If you have any more pictures of the damaged area and the view from the inside (if you can) I can offer some solutions that I have used to give a solid repair that will be as strong as the original skin before it was speared - so don't despair - soon it will just be a bad memory!
........but there is no excuse for the offender to sneak away without making an apology .
Hi Jim,
Hi chaps well today it finally happend l met up with a octogenarian with dodgy vision and a very fast electric boat.
My poor wave princess speared and assaulted murder wasnt far away from my mind but l was calmed down and given a strong tea by my club mates.
I have never had to carry out such a repair as this so l was thinking of doing a repair blog what do you chaps recon.
And guess what, the old fool packed up his kit and didnt even say sorry.
cheers all, Jim
[{"id":"163663997499","name":"163663997499.jpg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/163663997499\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/163663997499\/s","isImage":true,"ext":"jpg"},{"id":"163664000430","name":"163664000430.jpg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/163664000430\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/163664000430\/s","isImage":true,"ext":"jpg"},{"id":"163664002665","name":"163664002665.jpg","caption":"","url":"https:\/\/pl.model-boats.com\/media\/163664002665\/l","thumbUrl":"https:\/\/pl.model-boats.com\/media\/163664002665\/s","isImage":true,"ext":"jpg"}]
cheers all, Jim
