Battery placement
Obserwujący (6)
- DuncanPBronze
- mturpin013Bronze
Battery placement
Battery placement
Here are the instructions to view the media file that I uploaded to the site as a video media file. These instructions will allow you to download the file and then view the video. They are also on available on this web site for future reference. Enjoy!
Duncan
TO VIEW VIDEOS
Some videos open normally but others have a different way to open them.
They may say Invalid File, or Media File but if you click on them a new page will open.
At the top LEFT HAND corner there is a white arrow on a blue back ground, click on it and it will download.
Depending on the computer you are using it might open or give you the choice to select a viewer or just click on open.
Sometimes it will download it as an MPG4 file so you will have to rename it as an MP4 file to view it.
Battery placement
Many Thanks for your help. Looking at your photos I am going to take some of your ideas for switch placements.
Battery placement
Battery placement
That may be a better solution than cutting the bulkheads to get these to fit.
Battery placement
Battery placement
Here is a short video of Crash tender on the plane. After the short stop I switched it over to full power and also on the home run back. As a novice I didn't find it very stable at full power. I did add a splash rail to the hull which made a vast improvement and stopped the whole boat getting wet through!
Duncan
Battery placement
Battery placement
Battery placement
Have a look at my blog, most things are covered about the build of a crash tender
https://model-boats.com/blogs/37275
Battery placement
I buy tagged cells from Component shop so that I can assemble a battery pack to fit in the space available. Looking at your photos, if I were trying to fit 8 cells in the motor compartment, I’d make the battery up as two packs of 4 cells to fit either side of the motor. That way it would be also be balanced.
I think putting that much weight in the forward cabin will cause problems when trying to get the hull to plane.
I have a 5000mAh 3S LiPo in my 34” Crash Tender mounted laterally on the bulkhead above the propshaft.
( no photos as I’m away from home at present)
Graham93
Battery placement
The first two photos show where I think the batteries should go, one each side in the same comparment as the motor but this will mean cutting away part of the bulkhead to fit them in as they are too long. Will this weaken the structure too much? The third photo shows the only compartment the battery will fit in with no modifications. Woud this work or is it too far forward for the weight?
Any advice welcome.
Thanks
Polubione przez
Ładowanie…
