fitting props in correct rotation
Rozpoczęte przez Muskrat
5 odpowies 3 lubis Ostatnia aktywność: 4 lat temu
Thanks Peejay, That is what i thought so i will have to swap the motor leads over because i have no gears fitted. I will give that ago on the water and see how she performs
Cheers Jon
j a Easter.
Polubione przez Peejay
Is one of the motors geared to give opposite rotation? Left and right props must turn in opposite rotation. It seems that the prop with the larger wash is turning correctly, and the other must turn in the opposite direction by reversing the motor leads or using a gearbox.
Polubione przez Len1
Thanks Trev , That is how i fitted them and the motors all running in same direction but the boat gives out a load of wash from the rear so i am guessing the rotation is incorrect.
j a Easter.
Hi I am having problems with the running of my Fairmile, i was suppled with two left hand props and two right hand props, can somebody tell me were to fit the props and should the props contra rotate.
Cheers Jon
j a Easter.
Hi Muskrat.
Left hand Props on the port side right hand props on the starboard side.
Trev
Hi, I am having problems with the running of my Fairmile, I was supplied with four brushed motors for this boat with two left hand and two right hand props. I am unsure which prop should were and should the props contra rotate.
Cheers Jon.
j a Easter.
Polubione przez pressonreguardless
