Blocks
Rozpoczęte przez hammer
1 odpowy 1 lubi Ostatnia aktywność: 4 lat temu
Blocks
A dead bush from the garden supplied a closed grain timber. Cut to size on bandsaw & smoothed on belt sander. Slots cut on mill with a 2mm end mill. Could have used a drill. Cleaned the slots with home made chisel & small file. Shaping with a large file & sandpaper. Cut off & drive a brass pin through the centre. That was the most difficult.
Don't be shy just reply
Polubione przez Graham93
Blocks
Needed small working blocks for my model Irene. It sits in the window of our bedroom. I see it every morning & a few things worry me. Two sails need recutting. I can cut the stay sail out of the main. So will make a better main. The blocks are to big way out of scale. But they do have to operate. As I alter the rig to suit the weather.
