varnish
Rozpoczęte przez dennisw
5 odpowies 0 lubis 0 obserwujący Ostatnia aktywność: 13 lat temu
varnish
HI everyone.
Just a word of warning, I bought some Home base quick dry gloss varnish, its acrylic, water-soluble until dry, went on superbly, 3 weeks later its still tacky. can't finish it wont sand, just clogs the paper, will have to nitromores it and find another product
Etherow Model Boat Club
varnish
HI welshfenman,many thanks for the information I will follow it 🙏
dennis
dennis
varnish
Good information there welshfenman, it's always good to know how other people go about jobs, saves a lot of time and mistakes sometimes 👍
Alan
varnish
HI Alan, the best way I found to varnish the deck was the simple way. Rub down with 240wet and dry ,wash down with , white spirit, making sure that you leave no dust behind.
Dilute then fist coat of varnish(Wilkinson based is quite good) with50% with white spirit and leave to dry(not more than 12hrs. This can be repeated as any number of times as you like to get a rubbing down rub down and apply more varnish until you get the desired effect with 400 grade, Rub down gently, wash off, and apply more varnish. This method can be applied up to using 2000 grade paper, but all that will do will be to waste an awful lot of paper and varnish. Six coats should be enough. Works well on offshore boats as well
ONE point to remember, do NOT mix your varnishes, stick to poluruathane oil, or any oil based paIAINT do not use ronseal one coat !!!!
varnish
Don't make the mistake I made, I spent hours planking a deck, then used sanding sealer to get a really nice finish, looked really good, then after a few months it crazed.
If I did it again I think I would use Ronseal
Alan
varnish
sir,
could anyone please Inform me as to the name of the best varnish to use on a wooden deck.
thank you dennis
dennis
