Huntsman 31 1/10
Obserwujący (3)
Huntsman 31 1/10
It has a 10meter reception now 🤣.
That’s why the esc cuts of
Huntsman 31 1/10
I assume you are using 2.4Ghz radio so providing the aerial(s) are always above the waterline and higher than your motor/Esc interference should not be a problem now you have moved the rx away to the back. Make sure all your signal wire is well clear of any high current battery wires. It's possible you have a faulty (dirty contacts) rudder servo that is causing the rx problems. If your sailing waters are heavily weeded then that might be the problem. Hopefully the weather will improve and you can test further
Dave976
Huntsman 31 1/10
All my boats run on sla's or nicads even with brushless motors.
Huntsman 31 1/10
Huntsman 31 1/10
Huntsman 31 1/10
Huntsman 31 1/10
Coming along nicely. If your Esc is cutting out I suggest you purchase a wattmeter to measure the current/watts used as this may be the cause of the cut out. The drive chain should be free to rotate with no binding and the bearings lubricated. Looking at an earlier post I see the prop has a lock washer but does not butt up to the prop shaft. At the other end I cannot see a bearing and wonder if this may be your problem. NYou have not said what Esc or battery voltage you are using but if it exceeds the max design voltage for the Esc it will shut down to protect its self. Hope you manage to resolve whatever is causing the overheating.
Huntsman 31 1/10
Is has bin in the water for test run, but ESC cuts of, weathers is bad last weeks. Hope more testing next week
Huntsman 31 1/10
I am currently trying to get a similar hull completed but the mess left from gluing the strakes on will take days to remove.
Good luck with the superstructure and maiden voyage, and be sure to show us the finished boat on the water.😉
Huntsman 31 1/10
Huntsman 31 1/10
I am making the roof with 2mm ply.
Think that will look fine, mine is 1/10scale .
Huntsman 31 1/10
Looking good and well on the way to completion.
Dave 976
Huntsman 31 1/10
Huntsman 31 1/10
Sorry about the poor photograph of mine. Full-size boat shown as well.
Huntsman 31 1/10
Huntsman 31 1/10
Huntsman 31 1/10
Ik going to run a 3545 outrunner on 4S lipo
Global setup in the picture
Huntsman 31 1/10
Be interesting when you start on the superstructure. Have you decided on a motor yet?
Huntsman 31 1/10
I sanded the bow in the shape of the front with balsa blocks, and this how it turned out. Thinks it little to much flair compared to the original, but I like it
Huntsman 31 1/10
You said in another post that you scaled up a 1:16 drawing. I'm guessing you must have modified the area just back from the bow to produce the amount of flare that you have (which looks great and reflects the full -size boat) as I think it was less at the smaller scale.
Did you make your own strakes/spray rails as they are good as well.
I shall be painting the hull on mine soon when I've done the other three.
Polubione przez
Ładowanie…
