graupner mc-26
Rozpoczęte przez bombero
5 odpowies 7 lubis Ostatnia aktywność: 4 lat temu
graupner mc-26
IT WORKS😁😁😁😁
Tried the advice given and tried with the transmitter 1m away( as RodC suggested, my manual says 1/2 m,) but made no difference and was unable to set the binding in the receiver as I could not reach it. I then tried Colin Hs suggestion and the system showed "trying to bind"and the alarm stopped,I set the receiver to bind and that worked, so thank you all for the advice.
I had difficulty when I got the transmitter for my Dusseldorf fire boat and was ready to bin the Graupner transmitter and have ordered a 2019 Frsky taranis X9 lite as a replacement( now a second transmitter )so I can play to see which is better😊
THANK YOU AGAIN!
Len
Polubione przez Colin H and Martin555
graupner mc-26
Try reverse the stick position. Like reverse that position Servo setting.
Howard hager
Polubione przez Martin555
graupner mc-26
Try a bit more separation between TX & your RCVR, I have had something similar years ago, the components didn't like to operate when placed too close together. Say, 8' instead of having your TX almost on top of the RCVR. It's a bit awkward, but try it.
VA3ROD
graupner mc-26
Hi Len, I can't remember which one of my rc sets it is, but on the one it did the same, but set up by putting the throttle in full reverse while switching on it binds and works as normal .
Just a thought, it's worth a try.
graupner mc-26
Hi Len,
Just an idea is the throttle trim tab set to the middle position.?
Also do you have a three position switch on the TX ?
You may find it needs to be set in a different position.
Martin.
graupner mc-26
Just tried to check the electrics on my Finnmarken using my graupner MC-26 transmitter.It does not want to bind with the receiver but instead starts bleeping at me and showing"Thr to high" I have set to a new boat setting,all controls are at normal positions.the voltage at the receiver from the ESC is a fraction over 6 volts
Any ideas????
Len🤞
