Servos not working / moving
Rozpoczęte przez Jerry 001
9 odpowies 19 lubis Ostatnia aktywność: 4 lat temu
Servo testers hav dropped to 2 for abt $15 on AMAZON.CA
VA3ROD
Ditto to all that recommended a servo tester as they are inexpensive and help verify if the servo is OK and setting up linkage
LEN1
I agree either Colin a servo tester is a really good investment. I always check mine before fitting saves a lot of bother it also helps as you can set the Center point without having to connect all the radio gear
Polubione przez Len1 and RonBMK2
Have you put the plugs into the receiver the right way round? Also try the other sockets on the receiver. Just a thought. 😊
Colin makes great point. Servo testers are a very handy tool to have in one's tool box. Inexpensive and versatile.
I sometimes use a servo tester as a speed control with 360 degree rotation servos, ie, for radars.
Polubione przez Len1 and roycv and
Try a servo tester to check if the servos have malfunctioned.
If you don't have a tester then try unplugging and cleaning the plug and socket connections as sometimes if stood for long periods can corrode.
Polubione przez MouldBuilder and roycv and
Thank you all very much for your support. It’s working! 😊😊
Brgds
Jerry
Polubione przez DuncanP
I would always start at the batteries. Are they new or fully charged? Both transmitter and receiver? Does the receiver use a NiMH battery or a NiCD? How long has it been since they were charged and cycled?
You can check your receiver pack switch by eliminating it from between the battery pack and the receiver. I have seen them go bad and cause issues with voltage.
With your manual in front of you, rebind your receiver. When you do this, don't put the receiver right next to the transmitter. Some radios don't like this much and it causes problems. OK, you re-bound.
Had you previously set the failsafes? If so, you might consider un-doing them.
I am guessing that your radio and servos are set for throttle and rudder. If they are not working yet, try them connected to the auxiliary channels of the receiver.
BTY, has your receiver and or servos ever been underwater?
Are the servo cable plug polarized, ie, can they be put into the receiver in only one way? If not, check to make sure that they are installed correctly.
You could try some other servos and see if they work. As long as the cable plus fit into the receiver properly they should work fine.
Lastly, if you are still stuck, do you know anyone with a similar radio that you could try your receiver and servos on?
That is about all I can come up with. Good Luck
Polubione przez dave976 and flaxbybuck and
Are your servo and battery plugs the correct way round in the receiver ? Black wire to the outside) Battery plug in the battery slot on the receiver? Pics of your radio setup can sometimes help
Polubione przez RodC
After nearly two years Veronica is ready for the water, except I can’t get the Servos to move.
I am using a Planet TS2+2 2.4GHz R/C and 4 x AA 1.5v batteries connected to the Rx. The Rx and Tx are paired (solid red LED) and have been re-paired several times. The Servos are connected to Channels 1 & 2.
Can anyone come up with any suggestions as to where I go next?
Brgds
Jerry
Polubione przez DuncanP and Colin H
