RECEIVERS
Rozpoczęte przez NickD
4 odpowies 5 lubis Ostatnia aktywność: 4 lat temu
RECEIVERS
4 to 6 volts depending on which battery you use/
6 volt max and 4 volt min.😊
RECEIVERS
Thans guys for all your help 5.5v it is then
RECEIVERS
Just checked my 6CH flysky.
With a battery straight to Rx all channels have same voltage as input battery, used several batteries to test all with different voltages ranging from 5.4v to 6.2v
Using a battery with a BEC the voltage on each channel is limited to BEC output, so I was getting 5.5v.
Polubione przez RogerA1 and MouldBuilder and
RECEIVERS
What is the voltage out of each channel on a 3 or 6 channel Flysky receiver please.
