Creating Realistic Mast Hoops
Obserwujący (8)
- Newby7Bronze
- mturpin013Bronze
- roycvBronze
- chugalone100Silver
Yes, the mahogany rings will be strong as long as you wrap them four or five times around.😎
I have made mast hoops from copper pipe, plastic pipe, and copper sheet soldered, but none of these would pass as 'realistic', albeit they would pass the 'ten foot test' 😉
Granted they are not the wooden hoops of old, but certainly pass the ten foot test.
I use model aircraft aileron plastic hinges for goosenecks, one end goes into the sail boom and the other is free to rotate in a brass tube soldered to another wider one fitted on the mast. The bottom of the gooseneck is cut to size and a hole drilled in the centre of the hinge i.e. up into the plastic and a screweye inserted. This keeps the hinge in place and a boom vang can be fitted to keep the sail boom down.
I paint them out to hide them, i.e. I paint to match the mast and they go unnoticed.
I have several books by a Mr. Hobbs who was a model yacht 'authority' back in the 30's and 40's. Most fittings are illustrated and could also be bought from the long gone Webbs Fittings company.
I had to use his expertise when restoring a small yacht that used Braine steering, so the old stuff is still useful
regards
Rick
Should you have wider material you could take the shavings and make a complete roll, then cut it into rings of the required thickness. This could be less fiddly than making individual rings. Just a thought.😉
I will certainly keep this method in mind.
Barry
Grabbed my hand planer and shave enough long pieces according to the quantity of hoops that you will need.
2. Then I used a piece of brass tubing that I previously slipped over my mast making sure that will be round enough to fit over the thickest part of the mast with some slack.
I cover the brass tubing with a few turns of wax paper so when gluing the shavings together wont stick to the tube.
3."Carefully" grab the brittle shavings because they are very easy to brake. Soak them in water for at least one hour for more elasticity and have ready another container with a 50/50 mixture of white wood glue and water.
After the shavings are soft enough, pull them out the water and again, carefully wrap them with at least 4 turns over the waxed tubing and use any kind of clip to keep it together and let them dry over night.
4. After drying, pull them from the tubing and turn upside-down your favorite sanding block or have a piece of sanding paper laying on a flat surface and sand down the desired thickness and finish with a good sealer.
By using mahogany you will get a very nice color hoop like the ones showing in these pictures.
Polubione przez
Ładowanie…
