Height if thé letters on transom
Rozpoczęte przez hermank
2 odpowies 8 lubis Ostatnia aktywność: 3 lat temu
If you are looking for real small LED's for interior lighting I used ChipNano Pico and Z Leds
From www.Evandesigns.com They are in the USA
I used red 3 volt 8" wire (just a little thicker than a hair) you can also get 14" wire length
and 3 volt warm white https://evandesigns.com/products/chip-nano-pico-leds?variant=32158378885168
I used an adjustable voltage regulator to change everything to 3 volts so everything above deck is 3 volts including radar and nav light
https://www.amazon.com/dp/B085WC5G8N/ref=sspa_dk_detail_0?psc=1&pd_rd_i=B085WC5G8N&pd_rd_w=KnZkj&content-id=amzn1.sym.f734d1a2-0bf9-4a26-ad34-2e1b969a5a75&pf_rd_p=f734d1a2-0bf9-4a26-ad34-2e1b969a5a75&pf_rd_r=1WB7Z6E65FCDTMQYS1Q7&pd_rd_wg=qU1JQ&pd_rd_r=ad56aa31-b39c-45c6-ab9c-42fc412038db&s=electronics&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWw
As promissed please Fins Herent pictures of transom and side
Transom: 11mm
Side: 21 mm
Polubione przez Ray and Doogle and
