LEDs
LEDs
The man who never made a mistake never made anything.
LEDs
All the time I have wasted and how frustrating it has trying to get them to work. Sorry but I just needed to tell someone.
Philuk👍
LEDs
The spelling is intentional that what she said🤣🤣🤣
LEDs
I can answer for what I wrote, not for what other modelers say.
IIf you read carefully the fourth message of the topic "Led bulb / lights" you will see that all the answers are there.
The LEDs can be powered directly at their nominal voltage.
It corresponds to the voltage drop that an LED causes when electric current passes through it.
This voltage is a factory data like the operating current. You cannot make electrical circuits with LEDs if you don't know these data.
If you are able to supply the right supply voltage direct to your LED there is no need for resistor in series with it.
Since not everyone has the ability to regulate the input voltage but simply has a battery, it may be necessary to insert a resistor in series with the LED.
You said that you bought a voltage regulator if I'm not mistaken, so you don't need a resistor as long as you supply the right stabilized direct supply voltage to the LED.
It is necessary to insert a resistor in series with the LED when the battery supplies a voltage higher than the nominal voltage of the LED.
In this case the resistor will cause a voltage drop so that the right voltage reaches the LED.
For example, if the forward supply voltage is 2 volts and you have a 9 volt battery you need to cause a voltage drop of 7 volts (9-2).
To cause the correct voltage drop you must insert the resistor with the correct ohmic resistance value.
How do you do?
It's all explained in that message with very simple mathematical operations that apply Ohm's first law.
There are also various examples with different types of batteries and with direct power supply to the LED at 2 and 3 volts.
I also explained what the advantages and disadvantages of connections in series and connections in parallel are, as well as attention to the powers involved.
For this reason, if you want me to help you, it is best to find that information and perhaps share it with images that make it clear how you connected the various components to each other.
Don't worry, these are solvable problems.
https://model-boats.com/forum/135645
LEDs
Bob
LEDs
To help you I would need some information, because we have already written in the other topic what there was to say in general in terms of theory and practice.
Could you tell me what the voltage drop is (corresponds to the direct power supply to turn on the single LED).
I would also like to know if they already have their own integrated resistor and what their nominal operating current is. This information is provided by the seller and is essential for the correct use of the LEDs, so you should not have any difficulty finding them (since you have recently purchased them).
If I remember correctly you opted for the parallel connection.
Some photos would be very helpful.
LEDs
I am sorry to bring this subject up again,
I a bag of led wired bulb I put three in mast, they where working fine now when I come to mount the mast they aren't working 😔 tried each set of wires to each bulb nothing,so got my adjustable voltage board ,was using batteries two 1.5 volt yes 3 volt LEDs nothing checked all permutations of wires in case I mixed them up nothing 😕,so I thought I will get new ones out of the bag nothing am I missing something I am getting paranoid 🤔who said that tried my main mast already finished all LEDs work of batteries and power board,
I'm going to test the rest of the bag of LEDs about six more .
The strange bit is last night I checked the mast and was working all I did was to solder ends of wires in mast together so I could mount mast in cabin trying to finish main cabin 👍
Phil uk
Polubione przez
Ładowanie…
