Dropping anchor
Dropping anchor
I will try to take some pictures this PM and post them. It is a nice system, expensive, but it works well.
On my ARS, I lead the chain from the winch drum, up onto deck, over the "real" anchor winch and then down thru the hawse pipe. The system is still able to deploy and retrieve, most of the time.😂
Dropping anchor
Dropping anchor
The nature of the bottom is crucial to ensure the anchor can "hold" as well as be hauled up. Fine balance needed there too.
But generally you don't anchor in water deeper than knee depth, or say 30 to 40", which makes the concern almost redundant, provided the winch does not break the chain. Why I want a 1m drop is to position the anchors at an angle from the ship, thereby forming a triangle between the two anchors and the hull's centre line.
Our pond is generally clay at the bottom, so a fake bottom will have to be created to ensure the anchor can "attach" to it. Something like fish tank stones or cat litter might work (not tried). It will be Hall Anchors. Doubt if a Danforth or Admiralty anchor will "bite the dust" so to speak. I've seen people using chicken wire on a steel square frame but that is risky as well.
The practice in our club is to walk in. put a lead sinker on the bottom and hook the anchor manually (It does help to keep the boat off the dam wall, but does look utterly stupid).
Dropping anchor
Len
Dropping anchor
Then the clutch must also be strong enough to lift the anchor and chain without breaking it at the hull. Fine balance needed here.
Dropping anchor
I thought about an anchor winch for my future FB rebuild, but we have a lot of under water branches and growth to consider.
Florida ⛱️, USA
Dropping anchor
Otherwise it will gravity drop and retrieve.
Dropping anchor
Florida ⛱️, USA
Dropping anchor
Search this site as well as modelmayhem.co.uk and you will find various homemade, some commercially available, anchor winches.
As well, there is a commercially available unit from Krick, that I have used very successfully. I bought mine thru Cornwall Models. It is available as a single or twin drum unit. Be advised that the twin drum operates both drums at the same time.
I hope this helps.
Dropping anchor
Florida 😎, USA
https://www.dahmen.de/cat9165.html
Dropping anchor
I'm trying to design one in my head, where the chain is released to allow the anchor to drop to the bottom of the pond. (not winching it down)
In my scenario, the boat has two anchors. It drops the one, and then moves until the chain slack is taken up. Then it drops the second anchor. From there I need to winch it up so the boat is steady between the two anchors and not blown to shore by the wind. This will allow me to lower the submersible camera into the water using the stern gantry. Drop depth must be at least 1 meter. (36" in Hudson Bay 😊)
Polubione przez
Ładowanie…
