Scale deck gear
Rozpoczęte przez IanL1
7 odpowies 24 lubis Ostatnia aktywność: 3 lat temu
#8 1
Scale deck gear
Hi and thanks for the info. I have had a quick look but nothing is jumping out at me. Will keeop trying. Ian
Ian Langley
Polubione przez Len1 and hermank
#7 1
Scale deck gear
Hi, No I don't but if could have a look a real Venice water taxi you will see the types of fittings for the deck. I am currently making a steeering wheel but will need small imitation gauges as well. Not easy. Cheers Ian
Ian Langley
Scale deck gear
A GOOD DAY MODELSHIPBUILDER
try this website they have a hughe selection of items to be used on a modelboat.
Anchors,lights, for not saying everything you need on your model
WWW.MODELBOUWSHOPNEDERLAND.NL
they supply overseas and they have a translator in english
hope this helps
regards
Herman
Polubione przez RodC and Rookysailor and
Scale deck gear
You being in New Zealand is kind of remote for finding model boat accessories. Add to that searching for parts for a 1/10 scale Venice water taxi this probably falls into the unusual category. I see modelerscentral.com has a lot of parts.
As I just mentioned in anther subject, I have turned into a D.I.Y. almost for every model boat part. I do have a limited supply of commercial parts that mostly for smaller boat or larger boats in s small scale.
Without seeing what you are looking for makes it difficult to help. Photos or drawings placed in your posting might make a difference.
Florida ⛱️, USA 🇺🇸
Scale deck gear
Do you have photos of the deck fitting you are in search of? I have many items which may be suitable.
Scale deck gear
Hi Ian, I didn't have time to look to see if there was something that might be right for you, but here are three sites where you might find something suitable.
In one of these, a member of this forum was very happy to have found a well-made wooden lifeboat to assemble, at a very low price.
Select your language.
https://www.rocrimodellismo.com/it/547-minuterie-e-accessori-per-navi-e-velieri-in-legno
https://www.amatimodel.com/it/accessori-minuteria-e-componenti-per-modellismo
https://www.mantuamodelshop.com/
Polubione przez RodC and Doogle and
Scale deck gear
Hi all, I have been searching the net for deck fittings like bollards etc for my 1/10 scale Venice water taxi but have no luck. Also looking for chrome plated half round for gunwhale rub rail approx 4 mm or 3/16 wide. Can anybody suggest where I can look. Cheers Ian
Ian Langley
Polubione przez Len1 and GregHiltz and
