“Karoline” Dutch potato/fishing boat, billings boat kit, help please.
Obserwujący (9)
- roycvBronze
- jumpuglyGold
- Frankiesays1953Bronze
- luckyduckBronze
- Rogal118Silver
SPQR. Very good, i cant read italian but the photos and drawings are very discriptive.these will help alot in the coming days as i intend to make the sails ready for rigging "Karoline".Thankyou once again.
my friend is restauring this boat and has the sailplan. I will sent you a pm so you have my email. Can you sent me your adress details so i can sent a copy of the plan
regards
herman
Keep in mind that what I have described are only the fastenings of the sail to the mast, the boom and the gaff but they have not released to the real movement.
In an RC boat you can follow various methods to control the gaff sail.
I know three: the one I used (with a single sheet directly wrapped around the reel of the winch), the one RossM used of the double reel with two sheets (brilliant, very original, but for me a bit too complex in fact I discarded them at the time) and the most common one of the closed ring, a single sheet but not wrapped directly around the winch but attached to a rope that moves closed on itself thanks to the winch.
In any case they all move the boom and the sheets are attached to it.
The photo below is a sketch made on the fly to illustrate the solution with the sail tied to the boom, fixed only on two points.
As already said in some boats the tie to the boom is done as for the gaff, that is a rope that passes through the eyelets on the side of the sail and the boom itself.
Typically this type of sail (the "gaff sail") has three lashing sides.
The side hoisted on the mast is tied with wooden hoops, like the ones RossM did with his Bluenoose (I suggest you look at his model because he did a great job). On this side some boats use a rope that goes through eyelets instead of wooden hoops. I preferred to use hoops on my schooner for several reasons.
The side of the sail that is fixed on the gaff is usually tied with a rope that goes through the eyelets of the sail itself. There are several ways to do this type of lashing, I followed one that was consistent with that period and type of ship. If you want I can send you two or three drawings with as many lashing options.
The side of the sail hoisted on the boom can have two different ways of lashing. It can have a binding along the entire boom with a rope that passes through the eyelets (present on the edge) or only two binding points. One point is located on the corner of the sail called “Tack” and the other on the opposite side, that is, on the corner of the sail called “Clew”. I chose the latter solution.
The advantage of having rings (on a real ship) is that of being able to easily lower the gaff on the boom without removing the sails.
The advantage of having only two attachment points on the boom makes it easier (on real ships) to mess with the gaff sails (that is, collecting the sail on the mast with special running maneuvers), in fact on the Clew the binding is not fixed to the boom but is regulated by a rope and a block (pulley) that can be released.
I hope to have time to collect some drawings this evening to better illustrate what I have written.
But, I like a challenge, and will continue to look.
Polubione przez
Ładowanie…
