Rc connection issues
Obserwujący (10)
- Frankiesays1953Bronze
- Chum444Silver
- stotty1111Gold
I know that the batteries are all fully charged and have not had any issues with them before. I have a simple test rig set up so that I can test motors separately which I have used on the motors concerned and again they behave as they should 😊.
I'm thinking 🤔 that possibly the esc has gone into safe mode for some reason and reading about the other flysky issues, what I've done is clear the settings for now and maybe I'll try to reconnect tomorrow evening if I'm still awake and then update with any results. Thanks to everyone for their response and I'll let you know, bear 🐻 with us if I don't come back straight away as it's going to be a long week. Thanks again everyone 👍
You have received many useful tips and directions, I hope you will solve your problem.
When I read this forum I always learn something.
Please inform us if the problem still exists or if you have solved it. If so, how?
The connections seem correct.
If the Esc is working perfectly, I too (as Toradog did) immediately think of an insufficient power supply.
It is one of the first suspicions when one user manages to work and another does not.
In reality, it could be not only the voltage but the current or both that are insufficient. Brushed electric motors do not turn if supplied with the correct voltage but insufficient current.
In this case, the battery pack should not be able to turn the electric motor even if connected directly to it. You could do a test in this sense, if the electric motor does not turn even with the batteries directly attached then the problem is the batteries, or the electric motor (but I imagine that the latter has already been tested by you).
However, BobbyN's diagnosis intrigues me and interests me a lot.
Please Doogle let us know if it was the right one.
I had an issue with one of my Flysky I6 radios a few months ago. The rudder would work but the motor would not, I sought advice from fellow modellers on this forum but unsure how to link this thread. The bottom line was I solved the issue by going to a new model setting and it has worked fine since. It has resulted in the model 5 option on the radio being unusable because channel 3 does not work. On model 6 it all works well. Perhaps I could reset the radio but this would mean loosing all the settings I currently have for other models and I really do not want to resort to this.
So my advice would be to try resetting your radio to factory settings or just go to a new model and see if it works. If neither work then I guess it probably points to a wiring issue.
What is the voltage of the motor? Also, can you turn the motor over by hand?
Sleep good😊😊
What brand of ESc's are you using?
Are there fuses or circuit breakers in your system?
Are you running two motors independently? Two ESC's.
One thing you have not mentioned is what kind and size battery are you using. Also is it fully charged?
It sounds like you have used this very same set-up(rc installation) before in the same boat. Correct? If so, what if anything have you changed since it ran properly to when this current issue occurred?
I was taught(many years ago) to always start diagnosing at the battery. I would start here as well.
What, exactly is the ESC you are using? Pictures if possible. How many wires are coming out of it and how and to what are they connected to? What is the motor you are using?
There are a number of possibilities, but more info is needed. Sit tight before you go replacing anything at this point. It may be as simple as removing one wire.
I don't like electrics when it goes pear shaped 😂
Polubione przez
Ładowanie…
