Fairey huntsman
Rozpoczęte przez Wez
10 odpowies 56 lubis Ostatnia aktywność: 2 lat temu
Fairey huntsman
Hi Chris, Yes, on both parts. Then once you apply a little heat the solder will melt and run togther. In some cases you not need to add any more solder to the joint. Sorry if I didn't make myself clearer in the fist instance. Cheers Ian
Ian Langley
Polubione przez hermank and DWBrinkman
Fairey huntsman
Thanks Chris that’s just what happened been on garden duties today so will have another go tomorrow been and got some 60/40 solder today so should it be better than what I got in kit
Polubione przez hermank and DWBrinkman and
Fairey huntsman
Yes, tinning is applying a thin coat of solder to the area which needs to be meticulously clean otherwise the solder won't take and the joint will pull apart.
Fairey huntsman
Re to pre tining Ian do you mean little bit of solder on each part that I’m trying to solder together as went to pick the pulpit off today and not very good connection between each joints so need to re do them again
Fairey huntsman
Looks great and fits the part well. With soldering I have learnt that pre-tinning the mating parts makes for the final solder job so much easier. As I said before make up some sort of support to hold it together so all you need to worry about is soldering the joint and not have it moving around. Good luck. Cheers Ian
Ian Langley
Polubione przez Len1 and Wez and
Fairey huntsman
I did the plumbing in the kitchen some years ago with a bigger one but when I did some more recently I chickened out and used compression fittings!
The pulpit rails are something to do outside on a still day I think! 😁
Polubione przez Len1 and hermank and
Fairey huntsman
Ive not done too bad chrisf but I didn’t trust myself with a blowtorch see how you get on
Polubione przez Len1 and jumpugly and
Fairey huntsman
That's a nice job on the pulpit rail. Just the rear quarters and swim ladder, and you're good to go. Nice work 👍😊
Fairey huntsman
Nice job. That's something I've got to do but I've got 4 to do! The only soldering I've done is to wiring so it's going to be a first for me as well. I bought a small gas torch and some brass rod etc. sometime ago in readiness!
Fairey huntsman
So today’s challenge to make the bowrail (pulpit ) after a few days of trying my best to make the rear swim ladder and now I’ve got the hang of soldering thought I would make the new rail today don’t think I’ve done to bad just needs a clean up now as the old one was plastic and snapped while transporting home when I first bought it ,and hand rails new to replace old ones on the roof sections
Polubione przez RonaldM and Len1 and
