Motor Comparison
Rozpoczęte przez AtreiusModels
2 odpowies 10 lubis Ostatnia aktywność: 1 rok temu
Motor Comparison
Are you putting in a set of gears for your tugboat to give it more torque and less speed? Say 3:1
My tug is 23” length and runs with a 3 bladed prop, screw, wheel. You choose the term you want, but it doesn’t really matter to me, I understand.
Use a geared setup because my boat has a bigger motor and needs to be geared. If you follow Roy’s wise suggestions you can’t go wrong! He knows what he’s talking about.
Polubione przez Len1 and jumpugly and
Motor Comparison
I am sure the T4 is a nice motor but stick with te 385. It has a 2.3mm shaft diameter the other one is 4mm. and probably heavier.
Motor Comparison
Hello again, it's been a while!
I'm still working here and there on my 20" long tug boat, it currently has a 385 motor from Component Shop and the consensus was that this is one of the best motors for the size of tug.
However I recently found the T4A from Mobile Marine Models while checking to see if the bigger T12 was back (for a different model) and wondered if anyone might be able to offer a comparison please?
The T4A doesn't seem to have in depth specs listed like the 385.
385 Motor: https://www.componentshop.co.uk/385-dc-motor.html
T4A Motor: https://www.mobilemarinemodels.com/t4a-motor-585-p.asp
Polubione przez Len1 and SimpleSailor and
