engine etc etc
Rozpoczęte przez Guy O
2 odpowies 6 lubis Ostatnia aktywność: 11 miesięcy temu
engine etc etc
Hi Bob, many thanks for this information, very much appreciated.
engine etc etc
Good day Guy my name is Bob haven built several boats around this size , and for good performance as well as runtime and price . This is the combination that I use and is reliable . These items are all stocked on AiExpress so it is a one stop shop. The motors I recommend are Surpass or Rocket 35 width 48 length 1100 to 1450 KV . KV ( is 1000rpm per volt) . Both these motors run quite and have the mounting face to the output 4mm shaft , for better aliment to the prop shaft ( 4mm ). The prop shaft should have a bearing motor end and a teflon bush prop side ,the teflon bush is self lubricating in water. A Surpass KK esc 80 amp works really well , runs cool has both an on off switch and receiver plug as well a xt 60 plug. Battery lipo 4000 to 5200 mha 3s 40 to 60 C . This should give a run time of around 40 to 50 min depending on throttle usage .Prop size should be around 38 to 40 mm 1.4 pitch. This combination should give you a 40 to 50 kph speed and good run time . Hope this helps you ps lube your shaft with boating or silicon grease . Happy boating and use 4mm to 4mm universal joint.
Polubione przez thadlietz and Mike W and
engine etc etc
I am building the Gentlemans runabout re Sarik Hobbies, I have the plan and the mag instructions but it dosent mention anywhere the power / engine it will need and I must admit its not my strong point, any advice would be much appreciated.
