Adhesives
Obserwujący (5)
- RookysailorSilver
- jumpuglyGold
- Mike StoneyBronze
- merchant67Bronze
Adhesives
Cheers, Pete😊
Adhesives
Adhesives
Adhesives
Normal solder temp for brass is too high for white metal.
Adhesives
New to this. What does 'soft soldering' mean?? Are you referring to the temperature used???
Adhesives
Soft soldering works well with soldering grease and a medium soldering tip approx. 2-3 mm wide.
Brazing is not possible because white metal has a low melting point before the brazing alloy flows.
If possible, only use brass with brass. This is my experience, and I solder all railings with soft solder. It's easier to “rework”!
Where pressure builds up (steam engines), you should use hard soldering.
Okay?? Good luck!!
Greets Michel-C.
Adhesives
The brass wire is the hand rail.
Many thanks in advance
Polubione przez
Ładowanie…
