Aeronaut Pilot Boat
Obserwujący (2)
- RookysailorSilver
Aeronaut Pilot Boat
Aeronaut Pilot Boat
I enjoyed this project and was delighted with the outcome. I am now attempting a submarine conversion from a Revell kit and a much larger fire boat called the Dusseldorf.
Looking forward to your pictures if you have some.
Peter.😊
Aeronaut Pilot Boat
Aeronaut Pilot Boat
Saw your mail, answer soon, been having PC problems.🤔
Just about got 'em ironed out now 😊
Aeronaut Pilot Boat
I have a reasonable knowledge of electronics and wiring but my difficulty lies in the circuit board designs, especially when IC`s are involved. Fortunately this site has some very good people willing to help. I have been helped a lot by Doug, (RNinMunich) who is always happy to advise.
Due to only requiring a small quantity of electronic items such as LED`s at a time, I buy most of them through ebay. I would recommend bright_components for LEDs and resistors. They sell most things needed for the boat builder where electronics are concerned. 😊
Aeronaut Pilot Boat
Thanks for idea for making easier access to Rudder Connections. I have modified mine to similar to yours and all seems well so far. I have not continued with "above" Deck Building but that will be next on the plan. How "Electrical Minded" are you regarding LED wiring etc.? I am looking for a good Website, both for getting advice on Wiring along with suitable supplies for UK source. Any ideas? Thanks again. Ron
Aeronaut Pilot Boat
I have just fitted the rudders and controls last weekend. I have built almost the complete model but held off from fitting the deck until I had time to consider this problem. The best I could come up with was to reverse the control arms so that their screws fixing them to the rudders were accessible from the front after the deck had been fitted. Doing the linkages this way means that you have to bend the control arms to miss the strength rib in front of the rear skin and also you might have to reverse the servo travel direction on the Tx. I had to do this.😉
I have included a picture to show what I have done. it does not solve all of the problems but makes adjustment possible.
I have also included a picture of the dual speed controller. I know you have solved this problem but I have tested this unit and it works very well. I hope this helps in some way.
Peter.😊
Aeronaut Pilot Boat
Aeronaut Pilot Boat
Aeronaut Pilot Boat
Aeronaut Pilot Boat
I am currently building the Aeronauts Pilot Boat Kit. it is reasonably well advanced now but I still have to fit the electronics.
I bought two 400 sport brushed motors and was advised at a very early stage that two speed controllers were necessary. I looked into various solutions and found that Hobbyking sell a dual speed controller especially for two motors. it is a Hobbywing Quicrun 860. I hope this helps.😊
Peter.
Aeronaut Pilot Boat
Aeronaut Pilot Boat
Aeronaut Pilot Boat
It seems so long ago and I can't remember exactly how I did it.
However, I used canopy glue (which dries clear) to stick the glazing to the window opening as centrally as I could. Any gaps were successfully covered by the metal trim, which I fitted before the canopy glue dried so I could reposition the glazing if required.
Sorry I can't be any more specific but the end result was 'gapless'.
Steve
Aeronaut Pilot Boat
In have been reading this thread with great interest as I am currently making this Pilot Boat kit. I am about 70% there but have hit a snag that I have no answer for and hoped you could help.
I am trying to fit the glazing but have found it to be fairly loose in the holes. Can you advise as to how you glued yours in place without sticking the protective tape in place and how it stays there due to the gaps around. When did you fit the metal trims.
Thanks.😊
Peter.
Aeronaut Pilot Boat
I have just spoken to the MD, John and he can supply any parts you need.
His phone number is 01905 776073.
Hope this helps.
Aeronaut Pilot Boat
Aeronaut Pilot Boat
The most difficult part for me was skinning the hull. You need to be very careful and precise when lining them up.
Best of luck!
Steve
Aeronaut Pilot Boat
Aeronaut Pilot Boat
I think I will call aeronaut as the rubbing strake is included in every picture and my mother is a lawyer who advised me to just ask for them to send me one on the grounds of misrepresentation, (I know it says optional in the instructions but you only get the instructions after you buy the boat!)
Fingers crossed.
Thanks
T
Aeronaut Pilot Boat
http://jotika-ltd.com/Pages/1024768/index.htm. if you telephone and ask for John, the proprietor, I am sure he will help.
Aeronaut Pilot Boat
t
Aeronaut Pilot Boat
https://model-boats.com/builds/view/30601?t=1498411507
Aeronaut Pilot Boat
Thanks
Tintin
ps i have put a video on youtube etc but will post all the links on a build log im starting soon!
Aeronaut Pilot Boat
Tintin
Aeronaut Pilot Boat
I also look forward to your build blog and time lapse.
https://www.youtube.com/channel/UCqdJwdKWjLv2tEaiLqWnGJw
should take you to my youtube channel and one of the videos shows my pilot boat helping with some ice breaking on our lake.
Steve
Aeronaut Pilot Boat
I am looking forward to your build blog, it sounds as if it's going to be greatly detailed blog. I look forward to seeing how your Electro Magnet gets in incorporated in to the Pilot Boat Model!
I'll be waiting Patiently for your first post!
Ed
73
Aeronaut Pilot Boat
Thanks for the reply, I was just wondering about the lights!
And now I now, eventually I'll get a Pilot boat myself.
But for now I have your Pilot boat post to look at!
Oh, and now I know if I ever get the Pilot Boat to get the LED's from Ebay!
Ed
73
Aeronaut Pilot Boat
Anyway, many thanks for the help!
Tintin
Aeronaut Pilot Boat
I've been meaning to ask you. are the LED's included for the lights of the Pilot Boat? Or do you have to purchase them separately!
Ed
73
Aeronaut Pilot Boat
The motors were recommended by Howes Models when I bought the kit, together with the three bladed 35mm brass props.
Motors fitted no problem with plenty of room for all the other electrics. Don't know how the price compares with Graupner but I am pleased with the performance.
Hope this helps
Steve
Aeronaut Pilot Boat
I've really enjoyed reading this build log, I was wondering what the dimensions of your 540 motors were? because in the instructions (i'm about to start building it) it says to use a graupner 400 speed which is significantly smaller than the two graupner 600 speed motors that i was intending to put in it. Do you think they would fit? How much spare room is there?
Many thanks for any help,
Yours
Tintin
Aeronaut Pilot Boat
Aeronaut Pilot Boat
Aeronaut Pilot Boat
Yes, I was very pleased with the final model and its maiden voyage. it looks particularly good with all the lights on.
Just a reminder, be very precise when positioning the hull skins and don't use too much glue as the ribs will show through.
Best of luck.
Steve
Aeronaut Pilot Boat
Aeronaut Pilot Boat
I got all my running gear from Howes Models which is where I bought the kit. it was on their recommendation and I got 540 brushed motors, three bladed brass props and Mtroniks Viper marine ESCs. This gives me what I consider to be a good scale speed.
For gap filling I use Milliput and for small cracks, decorators caulk.
Cheers. Steve
Aeronaut Pilot Boat
Aeronaut Pilot Boat
Aeronaut Pilot Boat
My hull is up, trying to decide what motors I fancy, and where to get them from, along with props, controllers, switching unit, leds, and various other grubbing that's required. Like to get in one go, save postage, fed up with paying £3:50 or more for a one tiny item I forgot! Sure you know how it is.
Polubione przez
Ładowanie…
