Air Brush
Rozpoczęte przez cormorant
12 odpowies 3 lubis 0 obserwujący Ostatnia aktywność: 11 lat temu
Air Brush
plus £10 postage
it looks like the same model I have and mine works just fine.
When it comes to airbrushes I will also recommend a paasche "H" series unless your a skilled graphic artist a double acting brush is more trouble than its worth ( I own 2).
Do yourself a favour and by a quick release fitting for the brush and hose
https://www.everythingairbrush.com/airbrushing-accessories/hoses-adaptors/quick-release-couplings.html
https://www.everythingairbrush.com/airbrushing-accessories/hoses-adaptors/quick-release-couplings/airbrush-quick-release-fitting-tail-5mm-male-to-paasche-2877.html
the paasche airbrush has its own thread for couplings so your going to have to buy an adaptor anyhow.
Being able to disconnect the airbrush from the compressor without having to vent pressure is a time saver.
Air Brush
Just had an email from ebay, compressor only discounted to £40 item number 291610088212, have a look!!!
Etherow Model Boat Club
Air Brush
Hi Steve, pay with a credit card, just in case,
Air Brush
Hi Dennis
Thank you. Just been on their site. They do a kit which includes an AS 186 compressor, tank and loads of accessories for £89.99.
Seems to good to be true for the price but I am sorely tempted!
Steve
Air Brush
Hi Steve, check out airbrushheaven.co.uk I got a great kit of them.
Dennis
dennis
Air Brush
Hi Steve, your post about the compressor, yes mine is the AS186, mine came from ebay, lot cheaper than £100, uk supplier £80. as to the airbrush, I have both an airbrush and a spot gun, small or large areas
Air Brush
Thank you for your advice.
Steve
Air Brush
Steve,
It has to be up to you, of course, but is that what I'd call a full size compressor. if so, that's not too bad a price. An extra £19 for an airbrush seems fair, too.
Make sure it all comes with a guarantee worth the writing.
Air Brush
Gentlemen.
Martin, I note your last comment and I have spotted an Ajax Large Compressor with Tank AS186 at Cornwall Models for £100. For an extra £19 it seems it comes complete with air brush and hose.
What do you think?
Steve
Air Brush
Unless you wish to weather the model by airbrush I would ask yourself whether an airbrush is really what you need at all. if you just want to get a nice finish on a hull, consider a spotting gun. Also called a touch-up gun. it's effectively a big airbrush/small spray gun. Gravity fed, it'll do a hull in one go and need not cost you more than about £18.
A compressor is a far better investment. There's a huge lot of tosh talked about airbrushes and much of it at frightening prices. if you really want an airbrush for model general painting, a Paasche "Classic" model H is all you'll ever need. Bullet proof, no needle to blunt, external mix, easy to clean thoroughly, easy to use. I have one for colour, one for clear, but use the spotting gun more than anything else. I also have internal mix single and double action airbrushes for weathering and they're a pain in the proverbial!
Spend on a decent compressor with a tank instead.
Polubione przez Delboy and cenbeth
Air Brush
Hi Cormorant, mine was of ebay, not got a name on it, but I would strongly advise get a compressor with a tank, the tank prevents the airbrush chuffing in use, you get a smooth air supply, also get a moisture trap, I have one at both ends of the hose. and a good pressure gauge, practice does make prefect, old cardboard boxes and old paint, practice mixing paint and spraying. Get a good mask, mine is from 3m, again from ebay, and most of all, unless you are painting outside, make very sure you have quality fume extraction, not just a fan!! a spray booth is easy to construct, mine is made from shower curtains from a pound shop, the "rails" are a piece of rope strung from the roof of my shed.
Hope this helps
Polubione przez cenbeth
Air Brush
My next project requires careful painting and I am investigating air brushing, which will be a first for me.
Whilst not wishing to pay a fortune, I am looking for a good quality kit. I have seen FoxHunter KMS Airbrush Kits, both with compressors and one with an air tank.
Reviews are in the main positive, though there have been reported problems with the air tank and/or compressor.
Anyone any experience with this make, or can anyone suggest any others?
Thank you.
