Steaming ply- good idea or not?
You sure put a lot of work and detail into her! Hats off! 😉
Doug 😎
Since I don't have (and don't want!) a Google account I can't access your build photos 🤔 Would love to see them here in a Build Blog!😉
I know what you mean about 'never finished'! I first built my H class 1936 destroyer HMS Hotspur when I was about 14, I'm now 65, and she's currently undergoing about her 4th refit / rebuild, each time with more modern materials and electronics. in the old days I had to build a lot of electronics myself; speed controller, relay switching board etc. All good fun 😉 For Hotspur's funnel I used a similar technique to you, with 0.5mm 3ply. The original version was done with 1/32 balsa sheet! Cheers Doug 😎
https://en.wikipedia.org/wiki/HMS_Princess_Beatrix
and even more interesting story behind her build! 😉
https://sites.google.com/site/hmsprincessbeatrix/httpssitesgooglecomsitehmsprincessbeatrixhttpssitesgooglecomsitehmsprincessbeatrixScratch-built-Model-of-HMS-Princess-Beatrix
Good basis for a (retrospective!) build blog here?? 😉
I know the yard where she was built; was there several times in the last 20 years to discuss comms systems for new designs.
Cheers Doug 😎
Depends on how long you steam for. As has been suggested try on a scrap piece to find the best length of time to steam. You need to aim for the ply to be just soft enough to follow the curve you require then clamp over a former and allow to dry,
Sorry but it really is trial and error.
Sometimes it is better to use a solid infill and sand to shape for very sharp curves.
please let us know how you fare with the process
If you have a bit of scrap you can try.
Failing that I suggest wet with a sponge and bend in clamps overnight..
Wetting the ply, test some scrap ply and see if it delaminates, if not wet it and put it round a former such as a paint can hold it with bands or straps until dry.
Hope this helps
Polubione przez
Ładowanie…
