3d printing
Rozpoczęte przez marky
130 odpowies 208 lubis 0 obserwujący Ostatnia aktywność: 9 lat temu
#131
3d printing
I still wouldn't trust 'em! Too susceptible to damage.
My humble opinion - I think that there are some things best left to the pros, or at least other materials, and the 3d printers kept for more innovative jobs.
Like LCM hulls and V1s and 2s 😉
Or for repetitive deck fittings etc.
Each to his own, Happy printing - whatever comes out, cheers Doug 😎
#130
3d printing
Oops! I just noticed that Jarvo suggested the same approach. Still, great minds, etc, eh Jarvo?
Except that you just make the hole a 'cylinder' with a facet count of 6, i.e. hexagonal.
#129
3d printing
I have been guilty of thinking along conventional lines. There's no need to cut a thread in the prop.
Just design the prop with provision for a nut to be glued into it.
#128
3d printing
Props are probably best left to the experts and like Doug I use brass props and have found that performance / endurance and economy don't always come cheap.
I'm sure you can fashion a prop and find a way to attach to the propshaft but you will need a very good understanding of prop design to get good results.
If you want a good brass prop I suggest you contact Simon (ex PropShop) at Protean Design simonhiggins181@btinternet.com or 0797 7193759.
I will be watching with interest to see how this 3D print progresses!
Polubione przez RNinMunich
#127
3d printing
Hi Mark, that should work a treat, I still have doubts on if a decent surface finish can be achieved & like Doug said balance could be a problem.
But as they say up north, the proof is in the pudding😂
I'll have another go with props after the jeep has finished printing👍
Wayne
#126
3d printing
Just a thought, Wayne and RN. if you printed the prop with and oversized hole then epoxy a brass insert tapped to the right thread would that do both jobs? Especially if the insert was knurled and a slight push fit into the prop????
Etherow Model Boat Club
Polubione przez marky and Delboy
#124
3d printing
Re: 'tapped' plastic, more or less my thought.
Would need to be a hard but not brittle plastic.
Can you print brass?? 😉
#123
3d printing
Hehe, I'm not sure how the plastic would react to a tap, worth a punt I guess.
Always print a smaller hole than req'd & open out with a drill.
Tip for the day, run the drill in reverse, it still cuts & leaves a much nicer finish👍
Wayne
#122
3d printing
Hi Mark, look where your 'try something different' has got us!!😲
"Higher and faster!"😉
cheers Doug 😎
#121
3d printing
Hi Wayne, surely you can print them with the right size 'clearance' hole and then use a conventional tap to cut the thread?
Cheers Doug 😎
PS frankly I wouldn't trust 'em anyway. Thread could strip too easily and balance!? I'm currently converting all my plastic props to properly balanced quality brass ones. Cheers Doug 😎
#120
3d printing
John, as daft as it sounds, have a look at http://www.v2rocket.com/start/start.html
As for printed props, yes they are doable, I've printed a few but I've not mastered how to print them well yet, I'm struggling with the surface finish, threads that small are a nono though.
Wayne
#119
3d printing
Whoa! Propellers are a serious 3D proposition!
Not least as you can't have a threaded prop/shaft. Well, you could but it would be rat shit.
Shall have to think about that one.
I'm speaking from the design perspective, of course. The Machine does what it's told to do.
#118
3d printing
Hi Wayne Printed props would be handy. Also can you tell me where go to. get the A9 pics as a forumite on another forum has built a flying A4 and would love the A9 Cheers John 👍
a
#117
3d printing
Local University runs 3D Studio Max course so not sure if that is what is required but thanks for the suggestion.
#116
3d printing
T'is the season of night school. Check out your local college of further education to see if they offer any 3D printing courses.
Polubione przez SelwynWilliams
#115
3d printing
I guess 3D printing is going to be a big part of model making, we already have one club member who has one.
Does anyone have any idea where or how I can find a face to face 3D printing class (not an on-line one). I have tried looking on the web without success, any ideas would be very much appreciated. I live in the North West.🤔
#114
3d printing
Top prize to Marky, it is indeed a willys jeep, I found a 1/10 scale model on Thingiverse, I'm printing everything at 63% to get 1/16 scale. in comparison to the LCM3 it isn't taking very long to print, dependant on how it turns out I may print a few 😎👍
More pics tonight🎈
The printer runs off a transformer at 12 volts, to be honest I don't pay any attention to power consumption 🤓
Wayne
#113
3d printing
Thanks for that Dave the model of HMS Pickle looks superb and is the sort of thing we are looking to get. I will check out the poster software.
#112
3d printing
Hi Selwyn
Looking at the plans it may be possible to use PosteRazor available as a free download from many sources. Just Google and choose a source you trust to download.
It is actually a poster printing program and prints on A4 sheets which can be joined together.
I have used this in the past to enlarge line drawings to the required scale to produce the formers.
Won't be 100% scale but may be sufficient for your purpose.
A fellow club member made Pickle from a 2" square set of line drawings.
#111
3d printing
Think you're right Mark, I see the rear wheel arches but not the flat snout!?
#109
3d printing
Hi Wayne, you are such a tease did I see some wheel arches ?also when printing the landing craft did your electric meter have a nervous break down 😜😜👍
#107
3d printing
Hi Selwyn,
Like Delboy says, absolutely anything is feasible, my print volume in mm LWH is 220 x 220 x 240, I printed a 1/16 scale LCM3 landing craft, its in about 30 pieces that were all glued together, it took approx 6 weeks to print with the printer running 12+ hours per day...
Take a look at this video of a printed ship, this guy doesn't mess around!
Enjoy
Wayne
Polubione przez SelwynWilliams and rolfman2000 and
#106
3d printing
Everything is feasible. You have to realise the constraints of the system though. My printer has a maximum build volume of around 200x200x200 mm which is generous in the home printer category. Many are much smaller.
So, to get a model of any size, you might have to cut it into blocks which are glued together after printing.
Polubione przez SelwynWilliams and onetenor
#105
3d printing
These are the ship's plans I have and would want to have put into CAD and then output to a 3D printer is it feasible?
Polubione przez onetenor
#103
3d printing
If you don't have access to a 3D printer, it might be worth your while checking whether their is a local Maker space you can join. They will almost certainly have a 3D printer you can borrow and are likely to also have laser cutting, metal turning and milling, and a host of other facilities normally outside the pocket of the average modeller.
We are just starting up our Maker space in Guernsey but to find out if you have one near you, check www.nesta.org.uk/uk-makerspace-data.
Polubione przez marky and onetenor
#99
3d printing
Hi Wayne, is that Bluebird it's sitting on? Completed yet?
Donald still on holiday with his floozy??
Cheers Doug 😎
Polubione przez onetenor and Midlife306
#97
3d printing
Hi Wayne,pure dead brilliant as we say north of Hadrians wall,dare we ask whats next ?looks like something chain driven if the hints in the right hand corner are a teaser. Cheers Marky
#96
3d printing
Ok I've cheated, the 110mm diameter soil tube in the middle fits the bill perfectly, I'll take it into work tomorrow & get the ends squared up & shortened by 20mm.
Here you have it, a 1/16 scale V2 rocket👍
Wayne
Polubione przez onetenor and Imcc and
#93
3d printing
Hi Wayne, check out Herges Tintin book explorers in space for that elusive colour scheme +1printed Tintin ,Captain Haddock and Snowy .cheers Marky 🚀
Polubione przez onetenor and rolfman2000
#91
3d printing
Oops! Sorry about the German Wiki link. Guess I'm so used to it that I just don't notice any more🤔 Try this
https://en.wikipedia.org/wiki/Rheintochter
and this
lots of other interesting projects to see here!
or this
http://militarynavalhistory.net/
Click on 'World War Two', enter Rheintochter in the search box and scroll down. For some reason a direct link won't work, goes into an endless loop🤔
Cheers Doug 😎
Polubione przez onetenor and Inkoust
#90
3d printing
It's the pics of the tail section, they're both squashed on my iPad...
Cheers (Ta!)
Wayne
#89
3d printing
Hi Wayne, the guy made models for films but thanks for the advice. I will chat to my mates about the lines to go onto CAD.
#88
3d printing
Any time Wayne! (Jeder Zeit😉)
What went wrong? Have you also found that sometimes suddenly what you are typing doesn't register, or you can't load a pic?
As if the site server reaches a limit and doesn't accept any more inputs!🤔
Cheers Doug 😎
#85
3d printing
Thanks Doug, it helps massively if you can speak the lingo 👍
Things are moving on nicely with the V2, ciggy lighter for scale lol.
I also found a pic of a manned V2, now that would be an interesting project 🤔
Wayne
Polubione przez onetenor and marky and
#84
3d printing
Hi Wayne, here's some inspiration for your V1 Doodle Bug launcher!
cheers Doug 😎
http://www.modellbau-koenig.de/Military_Models_172-176/Cannon/Germany_WWII_V1_Missile_launcher_with_E-50_body_i80_60415_0.htm
http://www.modellbau-koenig.de/Military_Models_172-176/Cannon/V1_movable_Missile_launcher_with_E75_body_i80_60414_0.htm
and another WW2 rocket project?
https://de.wikipedia.org/wiki/Rheintochter_(Rakete)
http://www.modellbau-koenig.de/Military_Models_172-176/Cannon/Rheintochter_auf_E-50_i80_57063_0.htm
#83
3d printing
Hi Selwyn, when the guy quoted you £7k was he wearing a mask?
It shouldn't take very long at all for someone who knows their way around CAD to convert a line drg to a model. Get the model as a .STL file & away you go👍
I'll post more pics later Marky, it won't be flying anywhere though, I plan to make a launch trailer for it though🤓
Wayne
Polubione przez SelwynWilliams and RNinMunich
#82
3d printing
Wayne the rocket man ,soon be burning up the skies of Avalon .cheers Marky
