JOYSWAY DRAGONFLITE 95 TRANSMITTER
Rozpoczęte przez Les-Forbes
4 odpowies 3 lubis 0 obserwujący Ostatnia aktywność: 9 lat temu
Hi Les, yes use the mode buttons, it also mentions that the tension can be adjusted for each stick, you might want to try to slacken the (new) rudder stick and tighten the (new) sail stick, adjust slightly then re try to see how it feels. Don't overtighten as this will cause the sticks to either jam or snap off.
Etherow Model Boat Club
Polubione przez Les-Forbes
Thanks Jarvo. Do I still switch the mode setting under the battery holder.
Polubione przez Brucef102
Hi Les, unscrew the back and look at the gimbal mountings, there will be 2 or 4 screws on each gimbal, turn each gimbal through 90 degrees, refit the screws, switch the receiver plugs that should be it!!!
NOW LOOSEN UP PLEASE:
I have this Joysway transmitter. It's for my Dragonflite 95. The controls on the left operate the rudder and the controls on the right operate the sails. I'm use to it being the opposite. Do I change the mode selector switch under the battery housing and THEN loosen and tighten the screws as per instructed. It just seems long winded.
