Motor Mount
Rozpoczęte przez neilmc
7 odpowies 4 lubis 0 obserwujący Ostatnia aktywność: 9 lat temu
Motor Mount
Neil - I am alos restoring on old 34" Crash Tender and am at point of re-engining -could you detail which motor you have gone with and what kind of performance you get from it?
Ideally I wouold appreciate your set up details re motor/battery/esc and prop dia and no. blades. Also clearance of prop to rudder balde and prop tip to hull.....
Appreciating any advice for improving over what you have done...
Peter Dent
Motor Mount
Hi Jarvo
If you search with just 017000594-0 it does come show but only 19mm by 16mm hole spacing. There is another mount in the item like section but this looks to be small hole spacing as well.
Cheers Neil
Polubione przez SelwynWilliams
Motor Mount
Hi Dave, thanks for the info, still cant find the larger one, this one seems a bit small. Keep on looking!!!!
Etherow Model Boat Club
Motor Mount
Hi Neil, thanks for the quick reply. have looked on Hobby King, cant find it, have you got the code number and or the proper description please?
Motor Mount
Hi Jarvo,
Thanks for confirmation on mount was a little unsure as it all looks a little small compared against brush motor mounts.
The mount was from hobby king and was only £3.50 but then postage on top luckily made it worth my while with purchase of a new setup 😁
Polubione przez SelwynWilliams and Brucef102
Motor Mount
Hi Neil, that mount will be perfect. Just a thought, where did you get it? could do with a couple of them actually.
Motor Mount
Just a quick question is this motor mount going to be any good for me to use on my 34" Crash Tender or should I be looking to get another one?
