happy hunter
happy hunter
happy hunter
Hope this helps.
happy hunter
Click on the Icon to open. Then click Download in the top left corner.
(Trying out my new-found knowledge of PDF handling here😉 Thanks Rob 👍)
happy hunter
happy hunter
I would be happy to post pics of the plans if that would help. the plans show details of sub assemblies too.
Hope that helps.😊
happy hunter
Often wondered if such things in my early working days could account for some of my 'little eccentricities' 😉
happy hunter
I agree the commercial stuff is not nice.
I was suggesting the hobby plastic weld solvents freely available and used by fine scale modellers for joining plastic kits etc.
It is sold under a variety of names, the SHG catalogue lists:
PLAS1
Plasweld – Liquid Polystyrene solvent adhesive
Plasweld special solvent weld will bond Styrene, ABS, Butyrate, Acrylic and other
types of plastic materials. Easy to apply using a brush.
Bonds in seconds. The Ultimate Plastic Building Tool , 50ml bottle
2.00
POLY3L Precision Poly cement 28ml with needle applicator 3.25
POLY4 Polystyrene Cement 12ml tube 2.00
POLY4L Mek Poly Liquid Polystyrene Cement 30ml Bottle 2.75
PLAS7 Plastic filler. Special filler for plastic modelling 2.50.
There are many other suppliers in the UK and overseas.
Like most glues it is recommended that you work in a well ventilated area and avoid breathing the vapours as far as possible.
I do hope you weren't exposed to the substance for too long!
happy hunter
They are highly volatile (why it sets so fast!) and carcinogenic 😲
We used to use Methyl-ethyl-ketone many moons ago for cleaning circuit boards, I only had to be in the room with the stuff to get a migraine😡
Cheers Doug 😎
happy hunter
With plasticard it helps to heat in warm water when forming curves. Make a wooden (Balsa) template heat the plasticard, bend to shape and hold in place until cool.
I recommend you use MEK plastic adhesive with plasticard, the merest touch will allow capillary action to carry the liquid between the joints, I use a fine (old) paint brush. The glue is quick drying and actually welds the joint. Like superglue a little is best, too much and you risk melting the whole job.
happy hunter
Very good set of instructions, should help even the novice builder.
happy hunter
(Stupid auto dictionaries - switch off the Auto typing correction!!)
Glad to see you can make progress 👍
happy hunter
I am stuggling to get the curved bits right for the bow and the front of the bridge but will get it right eventually
happy hunter
www.krick-modell.de/shopfachhandel/Texte/ro1106 Happy Hunter Bilder+Lasertafeln zur Anleitungkl.pdf
Or here for the kit description and link to the build info.
http://www.krickshop.de/Products/News-2017/New-Items-2016/Happy-Hunter-Salvage-Tug-Kit.htm?shop=krick_e&a=article&ProdNr=ro1106&p=21061
Click on 'Documents' and then
'Construction stage photos for the kit Happy Hunter from romarin'
happy hunter
Polubione przez
Ładowanie…
