Pram
Rozpoczęte przez Ronald
6 odpowies 1 lubi 0 obserwujący Ostatnia aktywność: 8 lat temu
Pram
To be pedantic, a dinghy with a transom at each end, generally called a "pram" in the UK should really be spelt "praam". This is the correct Scandinavian name from where they originated
Cheers, Nerys.
Pram
Evenin' Granpa,
I would say Skiff yes, Pram no (except when it has wheels and a hood, otherwise colloquially known as a 'Blunder-bus'). 😉😁
Personal choice??
What you have built seems to be a Skiff, pointed bow. Then cut down to make a Pram,i.e. transom stern AND bow.
Cheers Doug 😎
Pram
Question to all you builders. Does the Pram need floor boards or not? How about the Skiff?
Pram
The first pram was too long for the Yacht at 10’ so I cut it down to make an 8’ Dinghy which suits this larger boat much better. After a bit more sanding, I will prime and paint it.
Polubione przez Dave M
Pram
Those clamps look very very familiar 👍😉
Pram
Looking good Grandpa, must do that for my 5 foot Caroline.
Pram
Working on a small pram to go with the Lobster Yacht.
