steam plans
Rozpoczęte przez hawkgripen
2 odpowies 0 lubis 0 obserwujący Ostatnia aktywność: 16 lat temu
steam plans
Is it plans to build yourself or kits of machined or part machined castings?
In the UK there are regulations regarding the use of pressure vessels to enable compliance with insurance.
I do not know what the regs are in SA but you should check this out before starting as material choice for boilers needs to be compliant before you start.
I have built and run several steam set ups and will point you in the right direction.
steam plans
hI there
is there anybody that can help me with plans for a steam engine and boiler for model boats
hawkgripen
s africahttp://www.stuartmodels.com/ try these good castings and good plans I built two of there engines one for missipI paddle steamer and the other for a tug boat
steam plans
hI there
hawkgripen
s africa
