Billing Boats St Canute Update
Rozpoczęte przez Richard7
2 odpowies 1 lubi 0 obserwujący Ostatnia aktywność: 8 lat temu
Looks good but yes sand till flush and seal 3/4 coats sanding between. Then the same with lacquer or varnish. Good look with the hull.👍
Polubione przez RNinMunich
Hello everyone, it’s been a while since l made a post about my ongoing model St Canute, mainly due to the heatwave we’ve just been through, however l have just completed laying the decking strips, which l have to admit was going well until the last few strips to the edge, boy oh boy did l struggle. I jumped the instructions as they do say to plank the hull first. At times l just sat there looking at the decking trying to get a reasonable edge and curve. I have attached some photos which some of you professional model makers will spot the errors, but it’s the best l can do so long am pretty pleased with the outcome. I have a question, should l now apply some sanding sealer to the deck strips? l am just a bit worried not to sand the deck strips too much. Any advice would be very much appreciated. I guess now l must start with the hull planking which l am apprehensive about, but hey ho it has to been done. Thanks everyone l will keep you updated from time to time, if anyone out there is also building this Billing Boat st Canute l would love to hear from you. Cheers everyone, Richard.
