Old Futaba servo wiring...
With the tester I can determine the optimum current the LED needs, and thus the dropping resistor for any given supply voltage.
Above a certain current, usually 20 to 30mA for the 3 and 5mm types, depending on type and colour, more current just produces heat instead of more brightness.
Pic shows my tester, only few quid😊, see mA scale along the top! Runs off a 9V block.
Re detector circuit: it's not very complicated, only 3 or 4 actual components.
The clues are good RF diode and a very sensitive meter! I just bought a couple of 300microamp full scale meters. Will do a little blog when I've tidied it up and boxed it.
Re Heli: can you post or mail me pics of the TX, RX and ESC please.
Brushed or Brushless motors?
Given manufacturer / model numbers I might be able to figure out what the pissibolities are. No promises though 😉
Sounds to me like the TX stick is set up for forwards / backwards like a normal car or boat set up. I.e. for 0 to full speed in either direction is only half the stick travel.
For aircraft 0 is full down, giving you the full stick travel for the speed range. The ESC probably needs to be 're-educated' and the TX throttle stick re-programmed, IF at all possible with the TX you got with the Heli.
Re " P.S. Signals come from where Doug?" - Don't understand the question John ??
been looking into the arduino route but only find it for 2.4 :(
Neat gadget👍
But I wanted a broadband device so I could also use it for some vintage 27 and 40MHz gear which I still use for my submarines, or just out of nostalgia. They still work so why chuck 'em out? is also good for checking the microwave oven. I let the Web do the 'running about'😉
In the meantime I found the little handheld analyser in the pic, covers 15 to 2700MHz. Cost a tad more than 10 bucks though🤔
Greetings from 'Up Over', Doug 😎
I was going down the route of building a 2.4GHz Detector/Meter until I came across this:
https://www.banggood.com/Lantian-Mini-High-Sensitive-2_4G-Frequency-Spectrograph-OLED-Displayer-Open-Source-For-RC-Drone-p-1247689.html?rmmds=myorder&cur_warehouse=CN
It works a treat and for that price it is not worth running around getting parts for a diode/capacitor/meter circuit.
Cheers from DownUnda
Mr Karslake just didn't know how to do it. A 'stick-in-the-mud!
Guess that was one customer who wasn't😡
Working models deserve lights like the originals.
Even boats like your Hornet probably had at least a white stern lamp to prevent them gettin' rammed up the whatsit😲
Was only pullin' your chain a bit about the LED tester and RF detector anyway😁
Ciao, Doug 😎
As I did tonight in fact. Hooked the FlySky up to a Futaba servo I'd put on the rudder for the Sea Hornet and it all worked a treat. First RC installation I've ever done! Made loads of statics, but no RCs before.
And you will NEVER find lights on one of my models. Mike Karslake, life long professional modelmaker, to a customer..."Sir I make models, not bloody table lamps".
Cheers, Martin
would have thought the name was self explanatory! 😉
In the attached pic you can see my Robbe Servo Tester at the top.
I used it to simulate the proportional signal from a receiver while testing your Taycol converter boards, not to power the motor.😲
Motor power came from the mains PSU in pic two, the battery eliminator circuit (BEC) in the ESC provided power to the tester.
The tester provides the signal to drive servos, or in this case an ESC, and saves the faff of setting up TX and RX and fiddling with batteries when I want to test a circuit or function before building it into a boat.
Oh, and by the way; when you get into lighting for your boats don't forget to buy an LED Tester as well 😁😁
You could also think about a simple RF Detector / Meter to check if your TX is actually transmitting 😁 Like I did with your TX using a home brew device - OR you could wait til I get around to publishing a Build Blog for the refined version I am making using a couple of RF diodes and a sensitive 300microamp meter 😊
Hi Martin,
My old Sanwa, and a few others from that era . 35 years ago, have the red and black wires swapped, i.e. black in the middle!
DO NOT plug these into a modern set or you will burn out the servo and possibly the RX internal wiring as well😡
Yours with red in the middle are OK, just chop off the tab to fit it to modern mini/micro RXs.
Polubione przez
Ładowanie…
