Taycol supermarine, to which prop.
Rozpoczęte przez Colin H
6 odpowies 3 lubis 0 obserwujący Ostatnia aktywność: 8 lat temu
#7 1
These days pitch seems to be expressed as a ratio of diameter, usually 1.4. 2.25" is close to 1.3 pitch on a 1.75" prop.
Polubione przez RNinMunich
Hi Colin, yes, I interpreted it as 1.75" diameter and 2.25" pitch.
Polubione przez Benny47
Hi boat shed, thank you for your input, I will consider all the offered options. Cheers Colin.
Cheers mate, that sounds good to me. Not sure I understand what the 1.75"x2.25" actually means, I assume it's something to do with the thrust. Like the pitch of a thread.
We all have different thoughts, but mine would be when you go to the lake to try it take them all with you and play around until you find the one that suits you the best. That is how I have found the way to find what suits my boat the best. You can also wait to see what others think and go from there.
BOATSHED
Hi Colin,
Taycol themselves recommended a 1.75" x 2.25" (44.45mm x 57.15mm) 3 blade prop. See attached spec sheet. So your 45mm 3 blader would seem to fit the bill. I would go for brass myself.
Just so happens I have a spare Rabeosch 45mm M4 thread right hander I have no use for if you need it.
With luck I'll have your motor reassembled over the weekend.
Either that or you'll get an 'Er Colin ... don't know how to tell you this but ...' sort of email! 😁😁
Cheers Doug 😎
Polubione przez BOATSHED
As I intend to fit my supermarine, after Doug has finished his magic, into a vintage Aerokits Sea Commander, what prop would be best, if I am using a 12v 7ah sla battery. I have available 2.5 inch 4 blade brass prop, 2 inch 3 blade brass, and various plastic 2 or 3 bade, in 30-35-40&45mm. Which would be the correct one to use.
Any thoughts would be much appreciated, cheers Colin.
