Got the bits, now what?...
Rozpoczęte przez Westquay
18 odpowies 4 lubis 0 obserwujący Ostatnia aktywność: 8 lat temu
I do have an inrunner, Doug, for my CNC outboard, but the one we're talking about here is an outrunner as it's the outside that spins and the innards which are bolted to a thick bit of aluminium.
You can get the idea from the picture. My dear bride has just bought me an early Christmas present of a new camera which, I hope will take pictures clearly when the sun isn't shining. So my pics should improve soon.
Never erd of 'em Mate!
So you've got an inrunner, lotsa revs but maybe less torque than an 'equivalent' size Outrunner. Be very interested to see your running results.
Cheers mate, Doug
Doug, weren't GiantCod an electrical goods company like Bang Good? I used to read of them, but never used them. Suddenly went nappoo.
2mm is unusual, but there they are and I had no trouble finding females for them. The motor is one of those little jobbies with a rotating can. Born to be used in a scale outboard motor with a dummy bit where the cord goes to pull start it. But then, where would you take the drive out of it (thinking aloud)? I have seen such a motor used in a heavy 3 footer which apparently planes, so my 2 footer with a step should be fine on 3 S. if it is, my other two similar boats will get similar set-ups. I had an Emax version of it, but gave it away, but they are still around and are only 7 quid.
Thanks for the link, onetenor. interesting range for sure and my little emax CF for 7 quid so I may well be talking to them, in the future. Although we're seeing the end of the boaty season soon. I might stay with them and get some finished for next Spring/summer.
This may help.https://www.robotbirds.co.uk/default/?SID=2e03407d3ced93e11fcaf9c82ac694fahttps://www.robotbirdAlso log onto the RCME site (FLYING MODELS) and look at the list of associated suppliers for more. Robotbirds have wide range of motors Many of which have variations of the same type. A really wide choice. Quick,reliable, friendly and very knowledgeable.Have a look. I've had very good results with them.👍
BTW Component Shop is also in Wales. Llanllechid,Bangor.👍😎
Polubione przez RNinMunich
"^ Both spellings are used in both British and American English. "Macmillan English Dictionary". Macmillan Publishers Limited. 2010. Retrieved 2010-04-14. "adapter noun [countable] /əˈdæptə(r)/ or adaptor an object that allows you to connect two pieces of equipment of different types or sizes a. British an object that allows you to connect several pieces of electrical equipment to one electricity supply b. an object that allows you to use electrical equipment in countries where there is a different type of electricity supply from your own"
^ Andrews, Jean (2007). A+ guide to managing and maintaining your PC (6th ed.). Boston, Mass.: Thomson Course Technology. p. 395. ISBN 0-619-21758-8."
https://www.wikiwand.com/en/Adapter
Component shop seems to prefer 'adapter'!
Whatever, glad you've got it sorted, or nearly.
2mm on the motor is unusual! What motor is it?
Who or what the blue blazes was 'Giant Cod'??? Google's answer -
https://www.independent.co.uk/news/world/australasia/mans-head-found-in-giant-cod-711407.html
HobbyKing is good for brushless, BUT I now also Google the Type/Model number of the motor that interests me on Hobbyking and sometimes I find the same thing cheaper here in Germany! Shop/Google around😉
Actually British people tend to go for "adaptor" for electrical equipment and "adapter" for people, although I have never seen, to my knowledge, the latter used in a body of writing.
What I needed and have ordered from Wales, is a Deans male to fit into the battery because I didn't want to change the battery connector for all your excellent reasons, going to a pair of 4mm bullet connectors. Bullets because I have a pack of 10 already and I believe I may have a few more in a box of bits. So I have ordered a Deans male one end of a 50mm length of 12 gauge wire to a male and a female bullet. All the other connectors will be bullets. The bullets on the motor are 2mm diameter and I will keep them as the wires are short and I don't want to fiddle with them, so I have some 2mm females coming, which will go on the ESC motor wires. 4MM bullets on the ESC to fit the new adaptor and we're there. The ESC already has a receiver plug fitted.
Thanks for the link. They look like a good source for the future. Now Giant Cod has gone, where would be a good place for cheap brushlesses?
Polubione przez Donnieboy
Hi Martin, spell it right and Lo and Behold 74 results!
https://www.componentshop.co.uk/catalogsearch/result/?q=adapter&cat=0
Personally, it's so easy I make my own, or swap connectors on one side.
I would have used the other half of the Deans and not put bullets on a battery - too awkward to get on and especially off with risk of damage to the model when it gives way! I'm not surprised there wasn't such an adapter.
Cheers, Doug
BTW; I strongly suspect that the bullets on your motor are 3.5mm, jus as they are on all mine, buy a few 3.5mil spare sockets in case you buy another ESC with open wires.
I put in Deans adaptor in search...nothing there. I found one on Ebay from Llandrindod Wells. Should be with me on Monday.
That'll do. BTW on your link, there was wasn't a Deans male to 4mm bullets, but thanks for the link. They do seem to have a lot of stuff at decent prices. I'll bear them in mind another time.
Not sure what you mean about component-shop. Just putting adapter into the search brings up loads of results, or there is a page available from the menu & if you can't spot the one you want just give them a call or e-mail & you will get a response today with delivery tomorrow a real possibility.
Not the cheapest, but available...RC Tech in Llandrindod Wells. Couldn't find the Chinese one again and didn't want the wait for the slow boat. Switch Electronics couldn't be arsed to answer the 'phone on a Friday morning, so they were out too.
Should be here on Monday.
Hi, just tried them. No evidence of adaptors and wouldn't come up in the search facility. Maybe I'll just get one from China and wait.
Just try Component-Shop (www.component-shop.co.uk) they have a range of adapters off the shelf & can custom build just about anything within a day or sometimes even same day if you say it is urgent. Certainly an adapter to go to/from bullets wouldn't be a problem (or expensive)
Thanks, Jim. I'll have a cruise round the electrical sites and see what's what. I still have to watch expenditure as I'm only on a pension, plus the odd thing I flog off.
Hi martin, yeah stuff comming from places far and wide are a pain in the stern. Bullet connections (the type they use on cars) are ok
not sure if used on greater current and amps they wont melt. I built more aeroplanes with electric power trains and l found that if l stayed with one or two types of connections it was much easier to keep a little collection of spares. EC3 and EC5 are the Blue coloured plastic/brass bullet plugs you can buy. have a look on Hobbyking web site at lipo batteries it will show you all the connections that are out there. jim dogge
Jim, it's a 3S Overlander which my local model shop are doing a deal on.
I don't know what XT 60 is or EC3/5. I have no Deans connectors. All I have a re the 10 pairs of 4mm bullets with black and red heat shrink. I had found an adaptor from 4mm bullet to Deans male, but it's a slow boat from China by the end of November and I ain't that patient! So bullets all round, I guess.
Hi westquay. that looks like a 2200 3 sel battery if it is and it has a black deans connector on it (they are usually yellow) in my opinion they are the best. XT60 if it is put a male xt 60 on the battery side of the esc and your own chosen bullet connectors on the esc to motor. I like to use ec3 or ec5 (depending on current draw) with a different coloured heat shrink seal, on each one. it helps if you need to reverse the the rotation of the motor. Take a look on line at the way the electric flyboys link it all together you will also get an idea of the connctions. Hope this helps. jimdogge
And yes, the thing they're all on is a master for a 1/32nd scale Vanwall transporter!
OK, I bought a LiPo tother day and some connectors.
This is now what I have.....a motor with little (2mm?) connectors on its wires, a 60Amp ESC with no connectors at all and an Overlander battery with a square plug on the end (Deans, is it) I also have a packet of ten 4mm bullets and heat shrink.
What now? Cut the Deans connector off the battery and replace with bullets, or buy a Deans connector for the ESC to battery? Cut off the little bullets on the motor and replace with the big ones which I should put on the ESC, too?
I suppose I'll have to increase the size of the hole in the ally heat plate next to the motor to accommodate the bigger bullets.
