AZIZ KIT
Rozpoczęte przez Lordgord
8 odpowies 4 lubis 0 obserwujący Ostatnia aktywność: 8 lat temu
Finally got some of the parts I am missing from the Aziz kit so have made a start on the build.
Do you think I have enough clamps on the deck supports?😀
It seems the more I learn
The less I know!
AZIZ KIT
hi anything like this as this is sitting in my workshop waiting refurb but mine is 17 inch long and all wooden hull
AZIZ KIT
Cheers Steve, that will be my very first job👍
The less I know!
AZIZ KIT
Is there a kit list in with the instructions?
If so then your first task is to identify everything and tick it off on the list. This is the first task for any kit build but in your case you really need to know what is missing before you waste time starting something you can't complete.
If you find things missing others on here may be able to point you at sources for replacement.
Polubione przez RNinMunich and Donnieboy and
AZIZ KIT
Pics of the Aziz kit as I received it. No box, but hey-Ho, onwards and upwards.👍
The less I know!
Polubione przez Donnieboy
AZIZ KIT
Thanks Steve, hope it works from my I-pad.
The less I know!
AZIZ KIT
When you open a post you will have the box you type your comment/update etc in and to the right another box with a + in it . hit the plus and it will take you into your file system. Browse to, and select, the file(s) (can be multiple) then hit open and they will all pop up in the box.
Things may be different if you are working from a phone. I can't help you there....too old for that sort of thing.
Steve
AZIZ KIT
HELP! How do I post my piccie's ?
The less I know!
AZIZ KIT
I have just become the new owner of an AZIZ kit (model slipway). It is unstarted and I am told by it's previous owner, that it may have parts missing, hmmmm. However, I believe I am up to the challenge, so, as soon as we get settled into our new abode and her indoors can't think of anything else that requires my immediate attention I shall make a start.😆 Watch this space!
The less I know!
