RC steam lever
Rozpoczęte przez Newby7
13 odpowies 3 lubis 0 obserwujący Ostatnia aktywność: 8 lat temu
RC steam lever
Hi Gary
I just should have ask you from here what thread size are the ports for the tvr engine are they 1/4 32 or 1/4 40 thread I want to order fittings in advance of the build.
Rick
RC steam lever
Hi Gary
I looked at your harbour post pictures your boats look great.
Yes after I ordered the parts I thought of a lever oiler combo will order that in the future when I can figure out the piping I will need and yes I can silver solder.
Rick
RC steam lever
Hi Rick, would you believe it is me yet again, I just thought you might like to check out my Harbour, as I have just put three boats in there, all with steam engines. Plus I was thinking if I where you which I am not but if I was. you will need to buy an oil lubricator for your engine, and Clevedon Steam has a lubricator with a throttle lever control valve attached to it, this would make a lot of sense. Question, can you silver solder as you will need to fabricate some pipe work? Regards Gary.
RC steam lever
Hi Gary
Yes I watched the videos great work .
I only have a small boiler but should get about 15 mins. run time and yes I'm hoping the eyes hold up the good thing is I can take my time at it.
The slide valve timing may be another issue I will have to learn.
Will keep you up to date when the engine comes in .
Rick
RC steam lever
Hi Rick, did you clock the two videos Danish steam I put on the video section?
RC steam lever
Hi Rick, and there is no news like good news, I promise you will not regret buying the engine, a wonderful piece of kit and runs like a Swiss watch. its crowning glory is the fact it runs on less than 30 PSI an easy boiler pressure to maintain. I am sure you will enjoy building the engine and sorting out the slide valve timing, and you will have a good understanding of exactly how it works. Hoping the old eyes are still sharp, for all those tiny screws. Regards, Gary. PS. The ideal boiler size is 3 1/2" dia. 6" length, will give you near enough 30 mins. run time.
RC steam lever
Hi Gary
Thought I would up date you just ordered the TVR steam engine and also the levers for RC operation your help in finding these items has been a great help will keep in contact on the forum.
Rick
RC steam lever
Hi Rick, I have just posted a bit of video on here which I found very interesting, mainly due to the fine detail of the two figures in the boat, and the fact they are animated via servos. The stuff in the boat has to be seen to be believed, from a Bulldog to a shotgun and tools and stuff everywhere. Very very realistic, and steam beats electric motors every time, welcome to the club. Regards, Gary.
RC steam lever
Hi Rick, yes Clevedon Steam is where I get a lot of fittings and stuff from, and another one is Macmodels, plus they sell the TVR1 BB steam engine which I use. if you don't manage to post a few photo's soon, I am sending you a camera for Christmas. Regards, Gary.
Polubione przez Joe727
RC steam lever
My Bad Escrich should have said that it's a globe valve and that's why I need a different valve.
Thanks Gary I will get in touch with Clevedon and it is good to have a place to get great information will keep in touch with you and one of these days I will try and get pictures LOL.
Rick
RC steam lever
Rick, it's myself yet again, and having been involved with steam for at least the last FORTY YEARS, I can answer most of your problems and help. Google CLEVEDON STEAM here in the U/K and this guy can help you with all the steam fittings you may require. Look for lever operated valves via servo, you could use this valve for a throttle valve, (steam control) or a gas cutoff valve. if you have any problems get in touch I am here to help. Regards , Gary.
RC steam lever
As far as i can understand you, your problem it's not so dificult to be solved, you have the valve but you can not command it to release the pressure, i suppose this is an On/Off valve, probably with a coil, in this case you only need a relay controlled over RC using one of your channels, let me know more information if you need more help
Trying to learn something, trying to help each others
RC steam lever
Hello
I have a steam plant to operate my new build but it has a shut off valve I will not be able to control the steam.
The company I purchased the plant from doesn't have an RC valve .
Ideas on shops I can search for the RC valve.
Rick
