Folding Bulwark????!
Obserwujący (1)
For all those interested and for those it may help, I attach images of another plan sheet for Hunan I have found showing a folding bulwark.
Not had time to study it fully yet. Hope I can comprehend its working to make it.
Toby
See the pictures.
Thank you for looking through your new books!
The picture you have uploaded is indeed a curious and interesting vessel. I have never seen such before. Could make a great ahs unusual model.
I believe I have the cargo winches sorted and hope to make those next week. Now to sort an anchor winch.
I have asked a number of modellers about folding bulwarks and I have been met with no idea expression each time.
Obviously not something modellers bother with out would seem.
Toby
I will keep looking for information for you,.
John
In the index page 200 mentions collapsible bulwarks and this is found actually on page 212 in the pdf. it seems to refer to lifeboats and albeit a few pages several are blocked from view as are some of the drawings. I believe it said one has to be a member in order to see those pages.
I don't think that the information concerns the ship's bulwark but rather the side of a ship's lifeboat.
What was it that you read?
Am I yet in the wrong link.
T
I cannot get the first link to work. it seems to bring up Google and images of hinges.
I have just found a downloaded file on my mobile concerning ship's boats. is this the file to the link you sent?
T
If you click on this one when it comes up you will get an immediate pdf download of very interesting stuff. I hope this helps.👍🤓
This also may help. https://archive.org/stream/shipsboatstheir00blocgoog/shipsboatstheir00blocgoog_djvu.txt it mentions folding bulwarks and their stowage.👍
I have just found an uploaded pdf of the book you cite. Off to have a peruse.
Toby
The drawing is very clear and confirms the sort of understanding I had thought from your earlier text.
Clearly the strap hinges however many they be per section would be logical and strong. Steve's farm gate comparison also would serve.
Two other questions arise, namely:
Would there be bulwark supports in these sections because they would have to be removable and fastened?
What is the locking mechanism when the bulwark section is upright in its home position and would there be some sort of keep plate to prevent the bulwark section leaning over the side.
I am just going to look online for the book you mention.
Steve
Another book which I find extremely helpful (and you may have it already) is Merchant Ship Construction by H.J. Pursey it doesn't seem to have an ISBN number on this one - it was first published in 1942 :-) good book though - and sometimes it comes up for sale on u know where :-)
Thank you again. I did appreciate seeing the earlier picture with a different style of opening. The latest image is a delightful period photo is it not. Beautifully lit and good colour with interesting detail.
John, re your view of bulwark hinging would you do me a favour and be kind enough to make a sketch of what you say in order that I might visualise more clearly where and how the fixings would look. From such I would be able to fashion something.
Also, with regard to removable railings when they are in situ, how are they locked or kept in place or do they just rely simply on long stemmed stanchions going in to the deck and the weight of the railings to keep in situ.
T
I have another pic which I found on the web but its got getty images ross setford stamped right over it :-) so this also shows large openings for 'gangway access' or 'access'
Thank you. This would be my view also and thus the difficulty arises as to know how they were hinged and fastened.
Toby
Steve
P.S. Look VERY closely at BLUEBIRD'S photo. Click on it to enlarge it.🤓
Thank you for another helpful bit of info. I am not sure what is meant by IIRC though. I asm assuming the hinge runs along the waterway.
T
Your method helped for I found an image of a door of ship yard number 550 and Hunan is 555. Likely Hunan had the same type of door? The ships were 2 years apart.
T
Thank you for the two photos. The second particularly is fascinating because it is the first time I have seen such. These bulwark sections open out but certainly it gives assurance that settings of bulwark were evident.
Toby
I will have a look for you for more
john
Thank you for looking into this subject on my behalf. Much appreciated!
What did you use as a search online because I have spent time trying to find any helpful cargo loading images and have not found an example. Did you save any of the images. Things like this and even such as correct doors present problems because the details are not on the plans.
If you can give me a lead that would be great.
I will now have another search.
Toby
I was just going over the plan of the cargo ship, Hunan, and found that I had missed a marking on it stating, 'folding bulwark'. I have attached an image of the plan.
Can anyone tell me about these. I presume that these bulwark sections could be laid flat on the deck to allow anything on the derrick not to crash into the bulwark. There are several of these sections in the bulwarks elsewhere and yet I can see no information on how these were held in place, or hinged.
For example its the bulwark section hinged at the bottom to allow the whole to fall to the deck or, does the top rail of the bulwark hinge back on top of the top rail preceding it and then just a flat bulwark panel rests on the deck.
Further how is it all locked in situ as a bulwark.
Any ideas anyone?
Toby
Polubione przez
Ładowanie…
