Tamar Lifeboat propellers
Rozpoczęte przez alan50
1 odpowy 1 lubi Ostatnia aktywność: 8 lat temu
Not sure if Prop Shop still exists - always found Simon to be very good with advice on choosing props (especially when plying him with tea & coffee at shows) . Seriously if he is still around he will definitely be able to give you some good advice.(and supply you with brilliantly made props , although a little more expensive than Raebosch)
Want to change to brass propellers on Model Slipway 1/16 Tamar Lifeboat.
Lost one of the original plastic propeller supplied in kit , and looking at Roboesch 40mm brass as replacements . Not sure whether to go for 3 or 4 blades and type A or C Type props. Good speed from the supplied props with kit running with brushless Tornado 3536 1050kv on 3s lipo. Any recommendations of what to go for would be helpful. Thanks
Polubione przez Brianaro
