WaterProofing and Painting
Rozpoczęte przez Tyler M
1 odpowy 1 lubi Ostatnia aktywność: 7 lat temu
To answer your question first, I would seal the wood inside and out with several coats of sanding sealer or primer - checking that the glue joints are sound first - and then use cellulose car spray for the final colour. Once decals are in place a final coal of car lacquer is a good idea. But you will find that everyone has their own approach to painting. Many people would advise covering with a fibreglass skin and epoxy, particularly as it's a racing boat...
Is it this Dumas kit? http://www.dumasproducts.com/product_info.php?products_id=391
I believe that that boat kit comes in different sizes, and has been around since the 1970s. It's a racing hydroplane, and not the first choice I would have made for a beginner to model boating! Here is a video of an electric one running:
You may just intend to build it as a display item, but if you are thinking of running it then you may find a bit more advice helpful?
I suppose that the first point to make is that that old World Engines radio is quite out of date. If it's 27Mhz it's still legal, but, even if you have all the bits for it I would advise against running anything with a vintage radio which may be unreliable. Don't throw it away - it's worth good money to a vintage collector - but a modern 2.4Ghz set will be much more reliable.
I see that the boat comes with an I/C motor. If you are not experienced with model boats I suspect that you have not used one of these? Again, these are becoming a bit of a specialist skill since so many lakes ban their use. Converting the boat to electric would bring it more into line with modern practice.
Common advice is for beginners who have little experience to go and talk to the nearest club, and I think that applies in spades here! Racing boats run fast, need careful expert set-up, and are easy to crash - possibly damaging more than just your boat in the process. A club will have more experienced members who know where to run the boat safely, will help you set it up, and may let you practice with simpler boats to learn how to do things properly before taking your (and your uncle and grandfather's) pride and joy out on the lake...
Here's someone else with a similar problem to yours... https://www.rcgroups.com/forums/showthread.php?1661638-1970-s-Pay-n-Pak-boat-NEED-HELP%21
Polubione przez Martin555
I recently was given a model boat that was started by my uncle and grandfather. I have experience with other electronics projects but have never worked with any RC boats before. My major and current question is what is the best method to waterproof the boat and what kind of paint and seal I should use on it. Thanks for any help you can give.
