New member - Boiler ID needed
Rozpoczęte przez tiger1john
4 odpowies 1 lubi Ostatnia aktywność: 7 lat temu
That looks like a complicated set up. I'm just about to start making a simple boiler to power a small twin V, so sorry I can't help with any identification. but its an interesting project.
The boiler arrived. I need to remove fittings in order to take the boiler cover off. I managed a few photos through the chimney. The boiler case measures 22 X 22cm square and 25cm high. There are two boilers in the case, plus a plethora of tubes. There are two gas burners with a gas regulator which is controlled by boiler pressure.
He who dies with the most toys wins.
Polubione przez mturpin013
Thank y. It is still on its way to me. When it arrives I'll take some better photos.
It looks like a Yarrow or a Backstaffe type, a peek under the cladding would be a help.
Hi. My name is John, and I am a keen collector of model steam engines. I apologize for joining this forum and immediately asking a question. I hope I can be forgiven.
I have recently purchased a marine plant because I wanted the engine, which is I believe to be a Stuart Sun. The plant comes with a boiler which is somewhat similar to a Stuart Mendip. Can anyone shed any light on what it is please?
Thank you.
