SEA QUEEN BULK HEAD TEMPLATES
Rozpoczęte przez larrywhetton
5 odpowies 0 lubis 0 obserwujący Ostatnia aktywność: 15 lat temu
why what happened to make it to that sad demise ?
is that broken never to float again , or have you disassembled carefully in order to carry out a restoration ?
thank you for reply , boat broken up now , but have a copy of plan ,
so will have to work out profiles .......larry...
larry whetton
have you got any photos of the vessel in her current state , also showing where the sections are missing ? my sea rover hull has now had a couple of the bulkheads removed completly along with the extra thick keel strengthener . by removing them and rebuilding the superstructure in balsa instead of plywood Ive saved lots of weight
HI, HAS ANY BODY OUT THERE HAVE A PLAN SET OF TEMPLATE DRAWINGS OF A SEA QUEEN
BOUGHT A VERY DAMAGED BOAT AT A CAR SALE BUT SOME BULKHEADS NONE EXISTENT
HARD TO NO WHAT GOES WHERE HOPE YOU CAN HELP ........LARRY...
larry whetton
