HMCS Rainboiw
Rozpoczęte przez Gdaynorm
24 odpowies 31 lubis Ostatnia aktywność: 7 lat temu
HMCS Rainboiw
Simply brilliant Norm👍👍👍
What else can I say!😮
Chalk it up Gadies and Lentlemen, your blabbermouth Admiral is speechless🙊
Polubione przez marky and Martin555
HMCS Rainboiw
Hiya.
If you check out EBay under stud like chain there is plenty on there of various sizes and cost.
Hope that helps.
Regards Bill.
Polubione przez Martin555
HMCS Rainboiw
Thanks mate. At present no-one seems to have any stud link chain in stock. Have finalised the boats - 3 cutters, 3 whalers, 1 motor launch and a dinghy - see pic
Polubione przez RNinMunich
HMCS Rainboiw
Jeez! You do come up with 'em don't you Norm!?😮
Testing me again?😉
Best I can do is the attached two pics.
One showing Rainbow, the other HMCS Niobe of the same era. Both at anchor with detail of the bow.
Incidentally; Niobe preceded Rainbow as the first HMCS ship by just two weeks.
Both pics seem to show the chain links as being as near as dammit the same length as the inner diameter of the portholes.
So I reckon if you take that as your guideline you won't be far wrong.👍
https://www.cnrs-scrn.org/northern_mariner/vol16/tnm_16_3_33-51.pdf
HMCS Rainboiw
Hi Doug,
Have a measurement problem. How long would anchor chain links have been in the early 1900s? I would assume about 18"?
HMCS Rainboiw
I have given Rainbow two cutters and two whalers, and think will add one 30ft launch and a sixteen foot dinghy. Does this sound about what she would have carried?
Polubione przez tim morland and marky and
HMCS Rainboiw
Aha! Cleaned me glasses and enlarged the photo!🤓
Now I see it, gun barrel hidden under the deck.
And the 'bar' is the outboard deck support.
Very good Chief👍
HMCS Rainboiw
Look carefully and you will see the gun shield underneath the raised deck. I have them facing fore and aft, so no barrel protruding.
HMCS Rainboiw
With regard to the workmanship Martin I agree with you.
But I know from helping with research for his previous models that Norm is a stickler for details, as far as humanly possible! 😉
Norm: that reminds me!
Have we seen any pics of your completed Dreadnought!?
Polubione przez Scratchbuilder and Martin555
HMCS Rainboiw
Hi Gdaynorm,
Ref "but probably best I can do."
You have done an excellent job there is absolutely nothing wrong with it.
Well done.
HMCS Rainboiw
Looks good Norm 👍
But where are the 6 (or 12) pounders?
Or is that the forward boat?
Under which there is no gun.
AH! No can't be. Must be the midships boat cos it's on the raised deck section.
But what's that bar arrangement under it which will get in the way of the gun?
Doug 😎
BTW: the decks are superb👍👍
How on earth did you do the swing around the catwalk??😮
HMCS Rainboiw
I've done one boat and falls, with rudimentary winches, see pic. Obviously winches will be painted. Not really happy with it, but probably best I can do.
Polubione przez Martin555 and RNinMunich
HMCS Rainboiw
I agree Norm,
Electric motors must have been few and far between in 1890, and pretty rudimentary and feeble. Doubt they had the guts to lift much.
I reckon they used lots of bods on the ropes.
Or Royal's tip of a central or under-deck steam winch.
I can't see any machinery under or around the boats and they surely wouldn't want to hamper the secondary gun crews with deck clutter.
Don't forget that the davits can be swivelled to turn the boats outboard!
Clearly visible in some of the photos showing some in some out.
Not sure how that worked though!?🤕
Carry on CPO, good work so far👍
Cheers, FLEET// 😎
HMCS Rainboiw
Thanks for all the thoughts! I rather doubt they would have been electrically driven then? I think I will simply give her a simple drum winch to be operated by hand. As they will be almost invisible on the model anyway, I'll have to let them go at that. Going to be tricky running the falls round them!
HMCS Rainboiw
Coming along brilliantly Norm, as expected👍
Apropos boat winches:-
Enlarging all available photos, including of the museum ship, as far as possible without being left with a pile of pixels🤔, I can't see any machinery under or near the davits. So if there was a winch it must have been under deck. So unless you're fitting glass decks forget 'em!😁
What I CAN see are the 6 pounders under the boats, 2 each P&S.
So don't forget the gun slits (embrasures)for them. See note below re these guns!
In one photo in the links below they show up like arrow slits in an old castle!
The DDE/DDH Royal mentions are from a very different era. Rainbow is from an era where ships had very large crews compared with later generations. So muscle power was available in abundance.
The centrally located winch is a good tip though. Might have been one but impossible to tell from the photos.
Another case of "yer pays yer money and ...."
Note:
If you are building the RCN version as of 1912 Norm then consider this-
"Before departing Great Britain (in 1910), the ships required alterations to make them suitable for training. This required new heating systems, an up-to-date galley, the latest in Marconi wireless, the enlargement of the cadet gunroom and principal messes and the removal of the obsolete secondary armament." I.e. the 4.7s!!
Odd! Attached pics purports to be Rainbow in North Vancouver 1910, with the 4.7s still in evidence!!??🤔 Maybe they were replaced with a newer version? Unclear!
Also-
"In 1911, the cruiser had her 6-pounder guns removed and replaced with QF 12-pounder 12 cwt naval guns." See attached pic. This was a 3" (76.2mm. Sound familiar? Oto Melara?😁)
https://en.wikipedia.org/wiki/QF_12-pounder_12_cwt_naval_gun
https://en.wikipedia.org/wiki/HMCS_Rainbow_(1891)
HMCS Rainboiw
Can't answer specifically and information hard to dig up. However, I have had some experience with electrically driven winches.
Just a thought or two. My educated guess would be a centrally located steam driven or hand operated winch. The various boat could recovered using a rope / pulley configuration to accommodate.
Onboard DDE/DDH (RCN) a electrically driven winch was used to recover the Ship's Boats. Winch was centrally located for use on both Port and Stbd sides of the ship. If the winch was unavailable, the muscle power of about 40 people would be used to raise the boat by rope and hand.
May not be what you are looking but should help in thinking though the problem.
By the way I am impressed with your choice of ship to build and will follow with interest.
HMCS Rainboiw
Hi Doug,
She is coming along, albeit slowly - see pic. Do you know if in 1912 would they have used a winch with the boat davits? Have to probably make twelve, and they will hardly be visible!
Polubione przez Martin555 and RNinMunich and
HMCS Rainboiw
"but am still surprised at wooden doors"
Well Norm, I guess this was around the period of transition from the Ironclads; black / white with yellow funnels (😮) and brass and wood all over the place!
HMCS Rainboiw
What I thought, but am still surprised at wooden doors. Whatever, they look nicer, give a bit of colour to a warship.
HMCS Rainboiw
Hi Norm,
If that's a true model, which museum models usually are, - at least 'as built or as taken over', - then it looks like all the doors were wooden. Also on the aft cabin.
Cheers Doug 😎
BTW: Don't forget the hinged gunnels for the 4.7s 😉
Polubione przez mturpin013
HMCS Rainboiw
Can't say Norm, not really my era, but here's a few more pics and a source you might find useful. You may be right about the doors, considering the dark colour shown in some of these images. Cheers, Doug 😎
https://commons.wikimedia.org/wiki/Category:HMS_Rainbow_(ship,_1893)
HMCS Rainboiw
Thanks. Will give that a try. Do you think it likely she had wooden doors to the aft bridge structure?
HMCS Rainboiw
Started a couple of months back on a waterline model of HMCS Rainbow. About time I did a Canadian ship with my living here!
As with historic ships, the problem has been getting drawings etc. A visit to the Esquimault Naval Museum netted a small number of photos, but they have a 1/4" to the foot model of the ship on display. I got hull profile drawings of her pre building in England, launch 1892.I have assumed the builder of the museum model had reliable drawings and photos. Any other info will be greatly appreciated.
That model has access doors to both bridges in mahogany. Comments welcome please.
