Workshop
Obserwujący (4)
- Newby7Bronze
- RookysailorSilver
Workshop
I will be interesting to see how long it stays clean LOL!!
Workshop
Peter.😊
Workshop
Good to hear you are getting sorted in many ways.
We all look forward to your updates.
Regards Bill.
Workshop
Rick
Workshop
Workshop
Workshop
Workshop
The machine is supported by four machine feet. I drilled 12mm (1/2”) holes through the wooden floor. Moved the feet over the holes and screwed in M12 studs. Above floor the cabinet sits on M12 nut off of the wooden floor. Then another nut and washer bolts the whole lot to secure. The feet as supplied had too much bounce so I made some large stainless washers to reduce this to 3mm (1/8”). This is very stable. The machine does not make contact with the wood at all but is fully supported by the 22cm thick reinforced concrete slab.
The wood house is only 3m by 3m so not too much room. I have a temporary work bench but I have a lot of sorting out to do. I will change the bench later.
Clamps etc are still packed away. Now that the machines are in place, I can organise the rest.😀
No plumbing. The wife brings me a glass of water from time to time.
Workshop
The problem with levels is that I always buy one long enough for the job. Many jobs later, this is what happened. I have a couple more old ones as well. By the way, the shed is level. Oh, I missed the machine level.😃
Workshop
Workshop
Workshop
Workshop
The Beatles were out.
It was Diane Ashley.
"Origin of the song according to Paul-
McCartney said the song was inspired by Apple scruffs (dedicated fans who hung around outside the Abbey Road studio, the Apple Corps offices, and the individual homes of the Beatles), who broke into McCartney's St John's Wood home. Diane Ashley says:
We were bored, he was out and so we decided to pay him a visit. We found a ladder in his garden and stuck it up at the bathroom window which he'd left slightly open. I was the one who climbed up and got in.
She then opened the front door to let the others in. The scruffs also stole a number of photographs in addition to clothes. Another Apple scruff, Margo Bird, remembers being good friends with McCartney – she would often take his dog for walks – and later got a job at Apple Corps. She says that she was asked to retrieve a photograph of his father Jim, which she did."
Workshop
Rick
Workshop
You say "I am experiencing a rather annoying water leak".
Well looking closely at the photos i would think it is coming in through the Roof, Window, and the Sides also where the Door should be LOL!!!
You also say:-
"It is also a problem getting into it as there is no door".
You are correct There is no door, LOL!
But again after studding the photos you could walk in through the sides then once inside you will clearly see the door frame so you could exit the shed from there LOL!!!
Workshop
I have built a small shed at the rear to take all of our garden tools so that the ship building yard is just that. I am experiencing a rather annoying water leak. My brother and I have had a look but we have yet to solve the problem. Might be coming in the window. It is also a problem getting into it as there is no door.😁
Workshop
Just put up as a temporary roofing while working on the house. Been there 9yrs (only supposed to last 3), waiting for it to rip off one day. Poly roofing is expensive (about $100 a 12ft sheet). Used that on my first house along the garage (closed in double carport) sides and still looks the same after 24 yrs.
Workshop
Workshop
Didn't want glass there as was too heavy and dangerous if it broke in the high winds we get here at times, (Acrylic flexes)
Workshop
Sorry to disagree, the polycarbonate sheet I have used for the last 35+years is still as clear as the day I bought it. It comes with a 30 Year warranty against weather, uv rays, impact up to 100kg per square meter.
Slightly more expensive than standard p/c. 2 off 4ft x 3ft cost us £62 including delivery.
Workshop
Workshop
Nerys
Workshop
For safety as our grandchildren play here I used 4mm polycarbonate safety sheet direct from the manufacturer cut to the sizes of my window frames.
Workshop
Workshop
In reply, Alice tells me she agrees with everything you say about the loop aerial. It has a motorised airspaced variable capacitor that can resonate it from about 3.4 to 10.2 Mhz. Yes it is very directional and should be on a rotator. It is a bit low to the ground but it does have a two sharpish nulls. It is designed for transmitting, but at very low efficiency! The capacitor won't arc over at even 100 watts of SSB! (Alice doesn't have a linear) but Alice uses it as a receiving aerial or extremely low power transmit because of the danger of high RF flux in the vicinity of it. The phone lines around here are overhead drop wires some are still unscreened pairs. She could be wrong as there are other noise sources, such as ethernet over mains wiring adaptors, SMPSU's and all sorts of poorly suppressed cheap crap but Alice thought that ADSL frequencies were something like 262Khz to 13.7Mhz well within the HF spectrum.
Nerys
Workshop
many of my (former) customers wanted to use these things on HF, mostly from aesthetics or stealth (🙄) aspects. Er! Efficiency? Wossat? 😉
They're not actually designed for transmission! Unless the circumference is a significant proportion (>30%) of the wavelength to be transmitted.
Even then, put significant power into it and you risk burning anyone near it!
Put just a few watts RF power into a small loop antenna and you get kilovolts on the antenna terminals, that's cos the TX current in the antenna is so high. So it needs a large expensive resonating capacitor with a very high breakdown voltage and low dielectric loss.
What you have there looks more like a DF receiving antenna to me.
I trust it is rotatable cos it's propagation/reception characteristic will be two main lobes 180° apart on the axis through the centre of of the circle.
You mention "frequencies it's designed for", what frequencies are you using it for?
I assume shortwave.
Surprised that you have interference from ASDL! Although I realise that ASDL uses frequencies from 26.075 Megs upwards to 137Megs for the Upstream communication ASDL connections are usually screened underground cables which shouldn't bother you!?
Unless there's a fault in the cable or your local distribution box😠
I only came across such loops (or more usually rectangular frame antennas) on board ships as an attempt to reduce the radar signature. Unfortunately at the expense of COMMS efficiency.
Cheers,Doug 😎
Workshop
cheers,
Nerys
Workshop
Nerys.
Workshop
Future exploit, Alice wants to buy a milk float when one comes up at a sensible price and not too far from home and convert it into a campervan.
Nerys
Workshop
Workshop
Workshop
Ex CEO of Air NZ and a million other companies, lots of $$$ Check out Gibbs vehicles, could be some model possibilities amongst them (like the Aqua truck) Unfortunately another Kiwi co (like Hamilton Jets ) forced to produce O/S, but we still have Rocket Lab !! (so far)
Workshop
We had a falling out later and he chopped the Vauxhall up and put it out for the inorganic kerbside collection, (probably to p me off) I only found out later that the Vauxhall was quite a rare version (full wind down windows, no 1/4 lights),- mind you I only paid $250 for it while at high school and old cars were worth nothing then, (once saw an XK120 at a car fair , bit rough but the guy (pipe smoking uni type) couldn't sell it for $400 because it smoked, (later kicked self many times!!!)
See Vaux in as bought cond (had run bearing) LOUD!!
Workshop
Workshop
Ye Gods and little fishes! What an incredible pair of ladies😮
Both my main interests, ship modelling and radio, in one convenient package👍
Not to mention general handiwork!
Where have you been all my life??
What's your call sign Alice?
I never went for a Ham license (had enough expensive hobbies already) but did work the night shift for a mate of mine in Hounslow during 24 hour competitions, so he could get some kip. Very interesting.
He was quite impressed once when I made him some contacts in North Norway. We deduced that the transmissions might have been bouncing off the Aurora Borealis, cos we had to track with it to keep the link, using a rotatable log periodic antenna, as it wandered about!
We had fun erecting that huge HF log-p in his back garden, but that's another saga🙄
Respect to you ladies, looking forward to your next exploits, in the Coracle maybe?⛵😉
Workshop
I have just showed my wife your new workshop and she said to me "if you want one like that make sure there is room for your bed"
I don't get what she means.
I think she meant get bunk beds, the bottom bunk for a bench and the top for shelves LOL!!
Workshop
See pics, wife's craft room 10x8.
And now building a small garage for my mums disability scooter, 8x5. This one we are building inside my garage as the weather is rubbish, once built and painted it will be dismantled into sections ready to bolt together on site in Aberystwyth. Both of them are built from scrap sheds from freecycle.
Workshop
Nerys
Polubione przez
Ładowanie…
