Bluebird?
Bluebird?
Bluebird?
It looks like you were spot on.
Bluebird?
Maybe this has solved the mystery.
I have just seen this on eBay.
https://www.ebay.co.uk/itm/VINTAGE-FRENCH-MODEL-SPEED-BOAT-1930S-RECORD-RARE-HYDROPLANE-DECO/123887723705?hash=item1cd848a4b9:g:1tUAAOSwtchdZCyG
Bluebird?
Bluebird?
Bluebird?
Bluebird?
What put me off the floats is they have a v bottom - this one appears to be flat - which is why I thought of a 3 pointer hydro centre in the first place - one thing we have not asked is what is it made from ? is it light or heavy ? Could be the so called exhaust is the mounting point for the outriggers...........
Or maybe an Airship...........like R1
Bluebird?
Maybe a French fan got hold of a float?
I wondered about the "R-1"!
Could equally well be just a complete fantasy build 😉
Bluebird?
https://www.google.com/search?q=beriev+r-1&client=firefox-b-d&tbm=isch&source=iu&ictx=1&fir=yQXY4b8Vmuc1FM%253A%252CEw_8hWpQV2bTvM%252C_&vet=1&usg=AI4_-kQe8fPxL109_VGAG7D0N-FUVz2Ufw&sa=X&ved=2ahUKEwjs_pyU8JHkAhVmwsQBHYvoCKEQ9QEwAXoECAUQBg#imgrc=fnAVbU_6KFwNuM:&vet=1
http://www.aviastar.org/air/russia/be_r-1.php
Cheer, Doug
Bluebird?
A distant bell is ringing - seems familiar somehow. Cant quite put a finger on it.
Brings to mind the attempt on a water speed record by some of the staff members - a 22' odd hydro powered by a Rolls Royce Griffin (ex Mk22 Spitfire) turned into the worlds fastest submarine (for a very short distance) on launching at Lake Kyle............
Bluebird?
I'm with you Red👍
But can't be an RAF Roundel cos the red an the blue are bassackwards!
Must be French. Unless that's green in the middle, then it's Italian.
Bluebird?
OR more likely it may be a float off a floatplane - turned into a boat- most of those had a hydro type step to get the aircraft off the water more easily - the roundels seem to be a RAF ones so its probably one - who knows it may even be a model of someones conversion........
Bluebird?
Any information would be appreciated.
Polubione przez
Ładowanie…
