Work with Balsa wood
Obserwujący (4)
If you need help or advice this site is the place to ask.
Everyone hear is very helpful, so don't be afraid to ask.
Now that you have explained what a "sticky" is, no the subject of this thread was working with Balsa and as I have not used Balsa wood for so many years I was just sharing my thoughts and experiences, as I might help the newer members that have not used this wood before.
As more experienced modellers I think that we tend to lose sight and forget the new guys to the hobby.
There is nothing worse than trying to understand some of the more complex stuff when you can't understand the simple stuff first.
Anyway enough woffel , the servo has it own built in speed controller.
When you strip off the gears and remove the rest you are left with this (see photo)
Motor and speed controller.
The pot you can use to zero then any movement from the TX stick will dive you forward and reverse.
You can replace the pot with two equal resisters ( I think it's 2k2 not sure at the moment.
I don't know what other motors you can use it on that is to technical for me.
Also if you remove the motor you can then connect led lighting circuits to it.
You can see this on utube.
A "sticky" simply means its kept at the head of the listing and never relegated to obscurity on page 2000 odd of the forum listing............
That's where I think hints and tips should be as its not a single topic but a thread of all types of hints etc which can be added to by any member at any time. That's why I'm offended by the the term learners instead of pupils - we all learn throughout our lives sometimes at the school of hard knocks...........
Incidentally it would be nice if you could give us all a lesson on how to make speed controls from old servos - I have two just begging to be done ..........Plus two huge fellows lying around somewhere - off Ebay for a couple of quid
I was just experimenting to see what the results would be.
I have plenty of poly filler so I just thought I would try it.
The boat I am trying to make is only to prove my drawing design for DG's EeZeBuilt site.
Try sanding sealer, it hardens the wood and seals the grain. I would never fill balsa before sealing it.
I spent a few hours in my little workshop today playing with this Balsa wood, and I tried an experiment.
I spread some fine poly filler on a piece of wood, let it dry and then gave it a quick rubdown with some fine sand paper.
The results were much better than I expected.
Although the wood is soft it did not dent quite so easily.
Later I will see what happens if I give it a few coats of varnish first then the filler.
Now why didn't I think of that!?🙄
Somewhere in the cellar I have what was called here a "Dampf Ente" Steam Duck!
Must dig it out and have a quack at it 😁
OK OK I was just leaving anyway!
(Slopes off to the cellar to go duck hunting😉)
I am not sure what a sticky is Red.
I have made clamps just by reversing a clothes peg.
do you have any photos of it.
martin555.
Easily held by spring type clothes pegs if you have not got enough clamps. They are not expensive so you can afford your own. If you cut off the angled nose piece they are much more useful and can clamp right next to a vertical surface if required with a cross piece etc.
When wanting to bend gunnel strakes etc we tried steaming in a long metal pipe (old fashioned drain) with a fire underneath - but not successfully . Then Dad hit on the idea of wrapping the wood in old sheet strips and pouring boiling water over it . That worked a treat with the Meranti we used.
So now I fill the kitchen sink with about 2" of hot water from the geyser and soak the strips in that for about 5 minutes. (Held down by crockery to hand). Quickly wipe dry and pin in place. Let dry then glue. Works with balsa and ply (aero) (no need to try liteply yet) and most model woods - some like jelutong and red cedar require a little longer soaking. We have a lot of old cleaning rags as trophies etc need cleaning from the residue left by laser cutting so I don't get into trouble. Dry rag wipes laser cut balsa edges for glueing nicely.
No doubt someone will tell me that this has been done and is sold by X.
Too right Colin,
The German ship model builders motto is
"Save anything that won't start to stink within a week!"
Cheers, 😎
I think I previously mentioned the possibility of thicker balsa cracking as it's usually not flexible enough across the grain, but if you can pick up some 1.5mm or 2mm you'll be fine for next time.
The only problem now is remembering what you have got and where it is.
By the time I managed to get to my stash I have forgotten what I was looking for. LOL!!
I have discovered two things.
Firstly I think I am allergic to Balsa is I am doing nothing but sneezing and I have not even started rubbing down yet.
Secondly I don't like working with it either.
I might get used to it in time !
This happened over night, and the hole thing is now glued solid and will not move.
Very different characteristics from plastic which is why you must be finding it strange. Not nearly as strong in some ways.
Another silly question.
Last night I glued this piece of Balsa wood and it was perfectly fine.
This morning I went to work on it and noticed this crack.
Is there a special way it can be fixed ?
Or do I have to cut it off and start again ?
As you know I mainly work using recycled plastic materials.
Yesterday I started using Balsa wood, I cannot remember the last time I used it.
It is strange stuff to work with.
I have taken the advice that you guys have given me on board.
And thanks again for the advice.
I may have some more questions later.
Sorry Colin😔
Do you mean this repartee Red? JB
Kiwi - much too far away to swim and cold to boot - not allowed to fly any more - puts a damper on travel a bit - the Kiwi crop spray pilots I met in Rhodesia many years ago all put me off - they were all heading for the US when they left us. Said they were just glad to be somewhere warm and where mists and snow hardly existed.......... went for a flight with one in a Snow Commander (old Bipe with a 500hp radial up front)- knees still shake when I think about it.......They used to spray Queala bird at night - (a little Finch type which swarmed in millions and could strip 30 acres of wheat in a day) by using a red lamp on a 20ft pole at the base of the tree they were roosting in. Mad and very scary...........
OZ is ok but has its problems at the moment, we're still chugging along reasonably well considering the state of some countries. main problem here is housing, costs have gone mental and young people have a massive job trying to get into a house unless they are both getting top money.
A lot of it is because the allowed thousands of Chinese to buy houses for themselves, their kids, investments and for rentals (even buying houses and cars for 1 or 2 kids while they go to uni here!) We couldn't buy a house in China though,"oh no you can't come here, but we want to buy your country" They own half the massive farm stations now and are into everything and don't obey many rules, (everything's cash if possible) Never mind, we're slowly re-training them to be Kiwis😉😊
Cohen & Kelly Bespoke Tailors!
Great British TV comedy,
from when the world still seemed more or less "normal" and folks could laugh even at themselves! This is the film version, it was also a must see half hour TV series.
😁😂 Doug
PS Kugels? Kugels here are balls, like Bowling-kugel!!
Of my tribe its only myself, better half and a daughter who remain in SA - brother & sister are in UK & son in the USA while his mother lives in UK as well. My sisters kids & deceased husbands relatives reside in the land of Oz. Most of my friends who were able to have sold up and left - Perth seems to be the favourite destination.
Was lucky enough to find a good local hobby shop in SA when first returning and spent hours sifting through the balsa stock . Bought enough to last a very long time . Unfortunately although the shop is still going its now some 1400 km away after our moves. Now the nearest supplier is a 3 hour drive away - and they charge nearly double what the original shop does.
Liteply was sourced from an internet dealer here on the basis its all pretty standard. Was lucky in that too as they gave a large quantity discount on an already good price for quality ply. Regrettably they are no longer in business.
We get the US 'Bud Nosen Models' and Australian plantation balsa here, and most of ours are in 3ft and 4ft x 3" and 4" widths, plus all the block and moulding shapes as well. I can get it from Art shops, hobby shops, an on line shop- JR Airsail (the ex NZ 'Airsail' company which closed and was re started as another entity, and is at a house and large shed in the country) - Airsail used to make small aircraft kits here which were sold round the world.
They also used to cut all their own balsa and sell it under the Airsail brand. I also get balsa from a large company called 'Spotlight' which I think is an Aussie company. They sell cloth, curtains and material, kitchen and art and craft stuff,-all sorts, and our local Aussie 'Bunnings' hardware warehouse has started selling it, so we are a bit spoilt for choice at the moment.
Polubione przez
Ładowanie…
