electrics
Rozpoczęte przez Jerry849
12 odpowies 15 lubis Ostatnia aktywność: 7 lat temu
electrics
Thanks Jerry, would like to hear of your progress,
Just checked the Turningy /HK ESC programming chart and see the default settings are: 1 - 2, 2 - 2, 3 -5, 4 - 6, 5 - 1, 6 - 5. These are quite usable with your boat.
Have changed them slightly as am using different motors, but they should work to get you going without a programming card.
Good Luck Rowen
Polubione przez rikster67
electrics
many thanks you have been a great help so far will keep you informed ,Jerry👍
electrics
That should be quite a performer once completed.
Stick with it and you will find the frustrations slowly disappear.
Between this site, Model Boats Mayhem and RCGroups you will find a wealth of information and resources.
The Precedent Huntsman is a popular build and there is much information around on it.
Good luck, never hesitate to ask advice if needed. I have been given vast amounts of it from many sources, all welcome.
Polubione przez Jerry849
electrics
its a project started many years ago but due to circumstances had to put it on hold just thought its time to fetch it back to life its the Precedentmodel of the huntsman 46 inch ply not fibreglass and i am making it twin screw instead off the kits one screw so wether it works or not we shall see but things not going to good at moment i could always sink it 🙄
electrics
That is encouraging!
From my experience of brushless they operate much more erratically than brushed at low rpm and start-up.
Not surprised one starts before the other. That is one of the reasons prefer to have each system on individual controls so can compensate. Guess that is personal preference!
The program card might be defunct, but would suggest follow the instructions in the article sent before condemning it. If you are in a local club perhaps borrow one?
Curious about your model, should be able to propel the QE2 with those motors - what are you building?
electrics
Have twin lever DX6I ,connected up to tx on y lead one motor kicks in then add a bit more throttle and second motor kicks in tried plugging e s c to program card ,nothing so obviously got a bad one will have to try source new one but all seem to be out of stock, so things look to be on hold now 😂
electrics
Guess should have asked, do you have a double control lever Tx or a pistol grip style? I have only ever used the two lever style so can usually find a spare channel.
Not sure about the pistol style - perhaps somebody else has an idea. Might need the Y connector after all.
Polubione przez Martin555 and rikster67
electrics
Suggest, lets get one ESC/motor going first and then move to the second. Put the Y lead to one side right now.
You need to put the 3 wire connector from the ESC into your receiver (correct way around), connect up the battery to the motor and see what happens when you operate the Transmitter - I assume the Tx and Rx are correctly bound?
The ESC default settings from Turnigy should get things working.
Once you have one working, move to the second. Put the red wire back into the second ESC, remove the first system and try the second.
If they both work separately - progress!
Would now reprogram both ESCs to the settings you think might suite your application best. They are in that article.
Once all works separately, remove one ESC red wire and tie back. You can then put both ESC connectors into the Y lead and fit to Rx. One control should operate both ESC/motors.
However, from my experience, if you have several Tx/Rx channels better to put each motor system on its own separate channel and do not use a Y lead. This allows individual motor control, which makes the boat easier to handle.
Might be better to now put these questions on the full site now so others can contribute, I have been known to make mistakes - which is why I ALWAYS fit fuses! I wanted the PM to send those instructions as am not sure how widely available they are.
Brushless are a challenge, but they do work well. a
electrics
Hi just reading your messages again i have e s c ,s on a y lead but you say control on separate channels so one in throttle on receiver so which channel for other lead, or is this a stupid question 🙄 i have disconnected red wire from one e s c so obviously will re connect this, have not read manual yet 👍
electrics
I did something similar using the “Elvon” function on my Tx. Does work well as the rudders have limited effect at slow speed
Polubione przez Martin555 and Joe727
electrics
Jerry, the last twin engine scratch built I did was a high performance deep V, so like the real boat where the rudders had less effect than the gears at docking speed, using a mixer really helped, reducing (and at slow speed even reversing) the inside engine when in a turn. The mixer goes between the receiver and the twin ESCs/steering servo. To program I disconnected the ESC from the mixer and programmed them separately. Works beautifully. Ed
Ed H
electrics
You have to set them up as two independent systems. Program the ESCs separately and preferably, control them by separate channels on your Rx.
You might be able to use a "Y" connector on your Rx to control them together. However, I have found Brushless motors erractic at slow speeds so the boat will be uncontrollable until moving quickly.
If you are using contra-rotating screws, then one motor should be reversed. In that colour coded set one wire must be reversed.
If you send me a PM, I have electronic instructions for using the HK /Turnigy progarm card, can forward them to you. It is essential in explaining what is happening.
Polubione przez Martin555 and Joe727 and
electrics
Hi all, new member,could some one enlighten me on how to set up twin e s c,s i am trying to run twin brushless motors (silver blue 3650 kv ) twin Turnigy 120 marine e s c,s twin 11.1 2800 mah lipos , have disconnected one red wire from one of e s c,s , do you program them separately or should they program together, got a hobby king program card but don't think it works, some advice would be much appreciated 👍
