Tall Paul Motor problems
Rozpoczęte przez Peter HS93
6 odpowies 0 lubis 0 obserwujący Ostatnia aktywność: 19 lat temu
HI Biggriff
I have now had the Solent plans copied and will photocopy the original instructions that came with the kit- definitely not for the beginner!
The photocopy cost A£2 and I expect the postage will be similar. I'll let you know the final figure next week.
Good luck with the restoration
--- ORIGINAL MESSAGE (REPLY ABOVE) ---
Dave,
Many thanks for your reply to my cry for help, I would very much like to receive all the info and pic's that you have, my e-mail is as follows:- nigelgj@btinternet.com.
As regards to the plans and booklet I will gladly pay for cop pies or alternatively I will get them cop pied at my local print shop and return the originals to your good self.
My postal address is - Nigel Griffith-Jones, 6A Laburnum Court, Smallfield Surrey. RH6 9QB.
Once again thank you for your prompt reply to my posted enquiry.
Nigel Griffith-Jones (known by friends and family as biggriff)
Have purchased the 900 BB motor intend to try it at 12 V first before 18 V if found to be necessary.
Two blade 50 mm plastic prop is on the boat with the older motor. this NEW MOTOR, 900 BB it does not have anything like the same fitting requirements it has just a face plate
(1) Water Cooling: not sure if it will need water cooling - it may safe to provide - need to purchase kit maybe ? any recommendations ?
(2) Fittings: looks like I may need to bent metal frame that will have length along boat and then bend up for the face plate ? photos ?
would appreciate viewing someones with a 900 BB already fitted ... very kind, can offer free coffee and biscuits
Tall Paul.
Romsey, Hampshire.
26/06/08 Skimmer scratch build compeleted with a satin varnish finish (plans with Model Boats magazine Sep 2007) almost skimmed today - needs a 5 X 5 prop as the one fitted is a heavy 'less screw' prop and it did not plane. Also need now to build the pilot's seat and a pilot (both need to be very light (balsa wood being used - doped and then painted).
Tall Paul.
Romsey, Hampshire.
Thanks for that Peter,
It has just the one prop and one motor and does not get anywhere to planing speed - as you say they are quite heavy.
Someone else on this site has suggested a 900 motor - not sure about what current would be taken from 12 V Lead Acid batteries that are fitted at present and with plastic two blade 50 mm prop.
Tall Paul.
Romsey, Hampshire.
have a look at the likes of a SPEED 900 BB run on 12v they are not to amp hungry and you can use a largish prop, wooden fireboats are a bit heavy to say the least and you would not need a special speed controler as the amp's draw will not be to great .
the motor you have where a good motor in there day but have been about for far to long prob about 25 years and are ok in tugs slow turning props , these graupner motors are a lot better built and more flexible
peter
Anyway I have started this as Its easier to comment on hear than on the picture Gallery , can you give us a bit more Info about the set up you have , speed controler amps It will take , and the type of battery , and someone on hear may have a set up that Is similar that works.
peter
