Fly Sky- small 6ch RXs
Rozpoczęte przez jbkiwi
11 odpowies 15 lubis Ostatnia aktywność: 7 lat temu
I found it in Dad's workshop when he died. I remember it as a child. Dad moved on to the new transistor and built himself a reed set, also a single channel Macgregor by the time he finished it. Proportional Radio was on the scene. I still have a 4 channel Skyleader and an RCS unit that were on 27mHz.Also a Rolls Royce Kraft Unit.
"I had a valve one until they broke into my workshop. You should have seen the battery! "
Or batteries Ian?
Low voltage for the heater, 90V for the Hi tension?⚡
Polubione przez RNinMunich
I've got one 'stuck on the wall' in my Sea Scout Ian.
No problem right across the lake here in Munich.
The really titchy RXs are destined for my mini Plastic Magic ships/boats.
Have used a Flyski in my Glider with an FS iA6 up to to 800-900 metres away no problem. The FS iA6 isn't large or heavy no problem to put it in a boat.😊😊 I had to look for it in my Sea Commander😂😂
BTW 2 ref Micron RX below:
"The RX2A does not support separate PWM outputs (not enough room on the circuit board for the connectors!)"
The Micron RX does support normal servos cos you only take the signal wire off the board, soldered in. Supply can be done externally. No on-board connectors needed😉
The nice guy at Micron actually called me and asked which port I wanted the nano servos I'd ordered connected to (I bought two sets for my Plastic Magic projects) and kindly soldered them in for me😊 He also put the motor and supply wires on for me and fitted teensy weensy plug/sockets for the servo and a JST connector for the battery.
Can't say fairer 'n 'at canya!
BTW 3! For those that didn't recognise it immediately, the RX at top left of the pic is the 35Meg Sanwa to go with my Sanwa Conquest FM6 TX. Got another kickin' abaht somewhere.
Polubione przez Martin555
Little receivers have smaller receivers upon their backs to bite 'em,
And littler receivers have littler receivers,
And so on ad infinitum! 😁
Attached a pic selection from early 80s to present day.
The little Micron job is a tad bigger than the RX2A and has 6 channels (up to 8 or 10 functions!) and includes a brushed motor 1.3A ESC! And drives 'normal' but teeny weeny servos😊
PS Just checked the 'destructions'; RX can also drive normal size servos - using an external supply, UBEC etc. It's compatible with my Spektrum DX6 TX.
Whole shebang, including all wiring and nano servo shown, weighs just 6g and can run off one LiPo cell or 3 AAA NiMh cells😉 There's even a programmable Cut Off function for the LiPo!
What next I wonder!?
BTW: the REELY RX is the FlySky/Turnigy iA6 rebranded by Conrad here in Germany, at nearly twice the price😠
Polubione przez Graham93 and Martin555 and
There are even smaller receivers. The photo shows the FlySky FS - RX2A receiver alongside a regular FS-iA6. Both are 6 channel AFHDS 2A compatible receivers. The RX2A weighs 1 gram.
There are a couple of downsides. The RX2A does not support separate PWM outputs (not enough room on the circuit board for the connectors!). Its output is either iBus or PPM so needs some decoding to be able to use it with regular servos. It's range is quoted as 400m, but I don't think that will be a problem for most boats.
Cost around £8 from China, or £10 locally in the UK.
Graham93
Polubione przez jbkiwi and RNinMunich and
Hi I use a Flyski FS-i6x Good Radio for it is FULLY Programable and you set switches and channels on it👍👍
I have had no problems with Multi Models I have added a Transmitter receiver cross-reference. For help watch, Bob Jacobsen from Hobbyconcepts set one up on a Tamiya Truck.
Turnigy and Flyski are the same company
Hi Martin, thought if anyone had these they might be good for tiny boats,-very small for a 6ch. Were very cheap on Ali Express or Banggood but the price has doubled lately, don't know what's going on - Chinese govt owns Ali Express now,- Jack Ma has 'Retired.' Still cheaper than
HK rip off freight -( 9ch is $16 nz plus freight which is probably 5 or $6 ).Ali Express is $18 with free shipping. Our scummy govt is now sucking 15% gst off us for on line purchases, which can make a big difference depending on what you are buying. They will be charging us for breathing soon!😐😠 No worries, the country will probably be broke after the virus anyhow!☹️☹️☹️😭
Hi Jb,
I am glad you mentioned this as i have a few F5-R6B receivers lying around in my draw and thought they were from a different rx/tx system.
And my Transmitter is a fly sky model FS-TH9X.
If you are wanting a small (45x21x15) 6ch RX for your Fly Sky TX, these (FS R6B) work with many Fly Sky TXs. I bought one to try on my 'Turnigy' 9x ( really a Fly Sky FS TH9x) and these work fine as should the GR3E 3ch (think that's a ground version for cars) (the 9ch is exactly the same as the HK one but with the Fly Sky sticker-don't believe HK dribble)
The TX I have is the V2 (probably because it's got a Turnigy sticker on it😀) but I have seen reviews saying the newest HK TGY 9x has been fiddled with (serial bus/ibus cppm/pwm support? -already an option from Fly Sky) and won't hold binding of more than 1 RX at a time (find that hard to believe) but I have around 8 bound to my 'V2'.
I bought a few more 6 ch and 9ch RXs as they were a lot cheaper than HK whose prices for shipping are just stupid (used to be $15 NZ to get a battery from HK Aust, Now $32 - 3x the price of the battery I wanted, Even a $5 item from Aust costs $32-won't be buying any more from them!
Chart is for Fly Fky TX RX matches and manual should help with programming HK 'TGY' 9x TXs
For most TXs from HK - read FLY SKY, HK changes the model numbers. Well worth a crack seeing what else fits your HK TX!
Polubione przez MouldBuilder and Ianh and
