Painting
Rozpoczęte przez George83
9 odpowies 13 lubis Ostatnia aktywność: 7 lat temu
Painting
Back in 1986, I painted this trawler with Floquil enamel over a glass cloth and resin base, using brushes. Then I sprayed it with Testors clear flattening spray.
At that time, Floquil bottled certain colors in a “Marine” line. I know they disicontinued the Marine line, but I still see their railroad colors on eBay. The main asset of Floquil, was that it was very thin so it wouldn’t cover very fine detailing, yet it still had very good coverage.
Polubione przez Martin555 and RNinMunich and
Painting
That is a tricky one.
As i mix up small amounts The only way i can answer this question is.
I try to get it to the consistency of milk.
I don't know if this helps.
Polubione przez George83
Painting
Martin555 thank you one more question what ratio do you thin your paint??
Keep calm and carry on!!!
Painting
My setup is a 10L Air Compressor and cheep airbrushes.
Painting
Hi Martin555 what setup do you use for spraying?? I have a compressor and a gravity feed touch up spray gun. I am guessing I could use the humbrol thinned paints in my setup..
Polubione przez Ianh and Martin555
Painting
Hi George83,
I spray my model hulls using Humbrol paint thinned with White Spirit.
Also water based Acrylic paint can be used.
Painting
Hi thank you for the reply is it car spray paint you use or tamiya spray paint??
George
Painting
I use spray can application for primer and finish coat but you need a well vented area to paint or wait for a sunny day with little or no wind to paint outdoors.
Rick
Painting
Hi everybody newbie here was just wondering what type of paint everyone uses for the hull’s??
