stringers
Rozpoczęte przez brianupyonder
4 odpowies 7 lubis Ostatnia aktywność: 6 lat temu
stringers
thanks for the advice mturpin013 will get my clamps out of shed tomorrow and give it a go
cheers brian👍
brian
Polubione przez scout13 and Martin555
stringers
I always steam and clamp any piece of wood that has a curve on it, It makes it so much easier to fit and make sure that you have symmetry, not steaming can lead to stress in a model during the build. I usually make a simple jig out of a piece of scrap MDF and just cut the profile in the piece giving two halves which are clamped together overnight, have a look at the link
You will see I use a kettle as a steamer but for larger pieces I use a modified wall paper steam stripper and a piece of stainless steel pipe.
Polubione przez RNinMunich and Martin555
stringers
If you are using 1/4" square ones I usually soak them in boiling water and then clamp them in position to dry.
On some models where they say 1/4" balsa I have used two pieces of 1/8" there by laminating them hope this is of some help
Polubione przez Martin555
stringers
hi all
when shapeing ply stringers is it best to soak them
cheers brian
brian
