Double Bit Bollard
Obserwujący (8)
- Newby7Bronze
- Stour-boyBronze
- RookysailorSilver
- mturpin013Bronze
Double Bit Bollard
Double Bit Bollard
Wood or brass they'll be first class!😁
Go for it Ron👍
If the rudder control rods get in the way; instead of taking the verticals right down to the hull what you could do is;
fit a large strong brass or alu plate (ca 1/8") under the deck section,
make the brass verticals, from rod not tube, with a 3 or 4mm threaded spigot on the end.
Then you can put nyloc nuts with large washer (PS belay washers, fit a single washer-plate connecting the verticals) under the deck to secure it.
Alternatively; drill and thread the vertical for a 3 or 4mm bolt. Preferably 4mm.
Personally I would favour the nyloc nut, but I guess a bolt and permanent Loctite would do the job as well.
But I guess the drill and thread would be easier to do if you don't have at least a simple mini-lathe.
Result, either way: the towing strain is dissipated along the deck.
You just have to make sure that that deck section is well and truly secured!!😉
Just a couple of thunks😉
Double Bit Bollard
Martin suggested running the uprights through the deck, and attaching to the hull. The rudder push rods run under the deck under that area, I will look at the best solution.
Count four frames from the aft going forward to locate the placement of the Bollard.
TTFN
Double Bit Bollard
I am certain that a man with your skills could make this with ease.
You could even use wood dowels to make it from.
My only suggestion would be is to have the vertical legs protruding through the deck and glued to the hull.
Double Bit Bollard
If it was my tug I would be inclined to make it from brass and silver solder all the joints.
With threaded rod inside the vertical tubes and protruding through the base, this would give a good solid mount.
I hope you intend to attach it to a non removable section so it stays put while towing.
Double Bit Bollard
"Evergreen MAY use an export company, but 'Javis' is not one, they are just a wholesale company."
I said they (Evergreen Scale Models) DO use an export company; to export from the US to wholesalers around the world, such as your Javis, and the three in Canada, amongst many others.
On their site you can find the wholesaler(s) in many countries.
If you then go to the wholesaler/distributor site you can find out who the retailers are in your country😊
https://hobby-exporter.com/
The parent company is based in Ohio.
https://www.evergreenplasticsusa.com/about-us
The division that interests us modellers is
https://evergreenscalemodels.com/pages/about-us
In Germany I get my supplies from Krick or Conrad😊
There are also about 8 craft shops dotted around the Munich area who stock it.
Whatever; Happy modelling folks👍
Double Bit Bollard
Here the links Ron.
https://www.pmhobbycraft.ca/
http://www.modelland.com/
Double Bit Bollard
PM Hobbycraft
Address: 2020j 32 Ave NE, Calgary, AB T2E 6T4
Phone: (403) 291-2733
Model Land
Address: 3409A 26 Ave SW, Calgary, AB T3E 0N3
Phone: (403) 249-1661
Double Bit Bollard
In absolutely no way was I casting any aspersions on Dave Watt.
I was simply pointing out that his site does not use HTTPS security and as such any info, including confidential personal data, sent to him through his site would be open to be read by any 15 year old with the nouse to do a bit of net trawling.
I'm pleased to hear that he does accept PayPal. Otherwise I'd have no way to buy from him.
Personal cheques are unknown here for years.
The last cheque I saw was a company 'Verrechnungsheck' sent to me by an insurance company.
That irritated me cos it cost me €10 to pay it into my account. too much manual 'labour' involved!!😠
They could have simply transferred the money to my account.
ASAP I changed insurers!
Double Bit Bollard
Cheers Pete
Double Bit Bollard
Exactly ED👍 That's what I meant.
Evergreen uses an export company and doesn't seem to sell direct to the outlet shops.
Double Bit Bollard
Nerys
Double Bit Bollard
There are three Evergreen Distributors in Canada, and I presume that they also supply various model shops.
Search time: ~2mins.
Double Bit Bollard
Just to be on the safe side, I scanned the catalogue and it was clear.
Peter.
Double Bit Bollard
That's not really the point Jacko.
He may well be the most trustworthy man in the universe.
But hackers and net trawlers are not!
Double Bit Bollard
I pay suppliers by PayPal except a few suppliers in the UK.
Caldercraft/Jotika ain't on of em!☹️☹️
Double Bit Bollard
What's not to like, go on have a go
Double Bit Bollard
Cheques? What are they Nerys?
I haven't seen a Eurocheque for good 20 years!
I'm sure he loses a lot of online trade like that.
Mine for example🤔
If he used PayPal he'd get my business, and others I'm sure, even if he applied the 3% surcharge to cover PayPal's cut.
Double Bit Bollard
www.mastman.co.uk.
Mainly bits for Thames Barges, but a lot more besides. Will also make to order.
Nerys
Double Bit Bollard
Nerys
Double Bit Bollard
The base is roughly 5cm x 6cm. Height of the two main pipes is 6 cm and are 1 cm dia.
I am building 3/4"=1'
If you can open the word doc the drawings are there.
Polubione przez
Ładowanie…
